[ View Full Version Of This Page ]
1985 XJS
All Forums » XJS » 1985 XJS
murrumbung2
5/25/2008 4:09:03 AM
G'Day, I'm new to this so please bear with me. I have a 1985 XJS that hasn't been used for a while and had a flat battery. A friend was helping me get it started, with a jump start, and inadvertantly conected the wrong terminals (Bad mistake).
It now wont start, and I've checked all fuses, and fuseable links, and everything seemes OK, I've also changed the I.C.U.
With the ignition on , I am getting power to the coil  (only 11.8 Volts), but no spark at the plugs.
Have checked the Ignition Amplifier Module and it has no power out, could anyone give any other suggestions, or is the I. A. Module stuffed.
Thanks Murrumbung2
cadillac
5/25/2008 10:43:18 AM
Welcome to the forums
Sorry to hear about your problem , you might have prolly "burned out" the diodes too .
jag_genius
5/28/2008 6:14:33 PM
check and see if your getting injectors pulse.. if not then sounds like your amplifier is done.. check to make sure your getting power and ground going into amp..   that amp is about $500  but there is a slight alternative..
murrumbung2
5/29/2008 5:32:01 AM
Thanks for your replys.
Since I posted my problem, have pulled the Ign Amplifier Mod apart and found the major part, (which tests stuffed ) is "GM 613 3M11".
Does this part sound familiar, and can anyone tell me if its still available.
Murrumbung2
jag_genius
5/29/2008 5:26:16 PM
you can get it from a local jobber or auto zone place...  a renault gio .. i think its called uses it there about $25.00
murrumbung2
5/30/2008 2:44:15 AM
Thanks, you truly are a genius, I'll try and keep you posted.
The trouble is I live out bush and may take me a week or so.
Regards murrumbung2
Related Threads
Return to the Jaguar Forums home page - Archive Home
