2.7TDi non-start / fuel issue
Hi all,
Background and brief tests-
Non running S-type diesel, 55 plate and 126k miles. Garaged for 3yrs. before me apparently would start with easy-start. (not witnessed by me)
Yet to check timing but given above I think issue is elsewhere and DIY tests lead to assume probably high pressure fuel pump - mechanically driven off camshaft etc.
No DTC (P codes) showing.
Question
I know above test with high pressure fuel lines is not recommended and yes I wore protective's and goggles etc, but understand that common rail diesels really do not need Glow-Plugs as diesel is injected under very high pressure -350+ psi. Can't afford to spend £100's at a replacement pump to prove fault if it is elsewhere and do not have a pressure gauge. - so:
Is there anything I am missing? Your views are really sort
With thanks
Paul
- Have checked Cam and Crank sensors and responding with voltage flux to CPU correctly although CPS sensor on the low side.
- Have checked OBD-II and nothing.
- Have checked fuel delivery from filter to High Pressure Fuel Pump and very good i.e 1ltr in circa 5-10 seconds.
- Have checked collected diesel from above test and fine - no contamination or separation in collected fuel.
- Have a poor 45amp battery, not 90-100amp as desired but enough to crank over for 30 odd cranks. Aware Jags are amp/volt sensitive but believe battery enough to effect start. When switched to 'ON' fuel pick up (sound) and glow plugs work. Difficult/Zero access to FVCV & FPCV (fuel volume and pressure control valve on high pressure fuel pump) to test via multi-metre- so not done yet, hence questions that follow.
- Have slackened off completely high pressure fuel pipe from common rail to injector no.3.
- No spray whilst doing so i.e no existing pressure in common rail
- A dribble of fuel from said joint whilst cranking
- Have not check EGR or DPF status as effectively these would normally cause bad running but not be sufficient to cause a non start.
Question
With thanks
Paul
I am suffering start problems, is the Glow Plug light illuminating for approx 3-5 secs ? if not immobiliser is still engaged ... double un lock with key fob. that is what i have been told, mine is still also intermittently not starting ok for 12 hrs then needs to be recovered... then ok when in Garage... so maybe engine ECU / data cable - connections.
joesoap
09-10-2015 01:09 AM
OkieTim
09-08-2015 04:48 PM
deanh
09-06-2015 08:20 PM
