Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
Possible coolant problem
Old 07-13-2016, 03:19 PM
mrjagger90's Avatar
Default Possible coolant problem
Hi! I'm new on here and just wondered if there were any experienced persons who could answer my queries...
Basically I changed a coolant hose three days ago and decided to flush the system and replace with new coolant, needed doing. Three days later and I'm still topping up with coolant, I've not put in 10L yet but not sure i got 10L out any way... Is it possible that there is a bit of air working its way out? Can't see any leaks anywhere. By the way the bleed screw on the top of the water pump is corroded tight.
It's a 2003 2.0d x type sport.
Thanks 😊🍻
Old 07-14-2016, 04:13 AM
mrjagger90's Avatar
Default Quick update
looked at the dip stick and no white milky stuff tastes of oil too, no milky stuff on oil filler cap at all but there is a hint of anti freeze when I tasted it... No pressure in coolant system at all...
Oil cooler breach??
Old 07-14-2016, 12:48 PM
GGG is offline
Received 16,757 Likes on 12,146 Posts
Welcome to the forum mrjagger90,
I've moved your identical question from General Tech Help to X-Type forum. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...t-leak-165931/
Please don't post the same question in multiple forums.
Gopi Hira
09-17-2016 04:26 PM
Paul_59
04-03-2016 04:55 AM
10-02-2006 10:12 PM
09-16-2006 05:55 PM
04-07-2006 08:12 PM
Quick Reply: Possible coolant problem
