engine oil
Received 10,756 Likes
Try, or check-ask for Lubrication Engineers oils-lubricants.
You will be surprised, if try them, on their products.
This is not an advertisement, I use them all around, cars, motorbike, factory.
7 years in a car, 12 years in the motorcycle, the same oil just filter change and fill up.
In the factory I work, 600HP centrifugal compressors running round the clock, 1081 rps, yes revolutions per second, not rpm, the impellers shafts (plain bearings), 9 years the same oil, the viscosity is up to you.
