Stripped Head bolt AJ27 V8
I've got a customer 2000MY XJR for an overheat problem. Sometimes the engine will over temp, sometimes will run for an hour OK.
I expected to find a faulty head gasket or cracked head.
Removing the head bolts revealed the problem. Bank 1 center bolts were loose to remove. Stripped aluminum threads on one of the bolts and exhaust corrosion on the other. The bolts were the 'newer poly-drive' or RIBE head bolts so they were replaced at some time after the engine was made.
Most of the other head bolts were tighter and there was evidence of 'blow-by' between cylinders 2a & 3a.
I need to install new threads in the block for the replacement head bolts.
Time-Sert kit #7580 (M10X1.5mm) will be needed to install the threads 75mm below the block deck.
I wondered if anyone has repaired the block with one of these kits and would that someone be willing to rent/sell the used kit for this repair.
There are usually 14 inserts per kit and additional inserts are available for purchase from the company.
The kit is around $430 with shipping. If nobody has one to help me out I guess I will buy the kit and maybe the next person will buy the used kit from me.
I have not seen this fault before when I have removed Jag V8 heads so it is not common.
Let me know.
bob gauff
Let me know.
bob gauff
Is the installer specific to the M10x1.5mm insert? Or one installer fits all?
The Time-Sert system is the specified tool for the repair of stripped sparkplug
threads on modular Fords. It is a very common repair. So if the installer is
universal and you have a contact at a Ford dealer maybe all you will need to
purchase is the two inserts(and the customary donuts).
Because the problem is common, there are even mobile time-sert installation
services. Search: modular ford time-sert
Each Time-Sert tool kit is UNIQUE. The M10X1.5mm is the size (as opposed to the M14X1.25mm sparkplug set) that I need. The #7580 is REALLY LONG to reach the 75mm depth below the block deck. It also has a 'guide plate' to ensure a perpendicular hole.
I have the Time-Sert BMW M14X1.25mm LONG REACH sparkplug tool set. I also have a few other sets for M14X1.5mm, M10X1.25mm etc. for flush surface threaded holes. I even have the M10X1.00mm for the VW Diesel glow plug thread repair in the TDI head.
I called the machine shop I have used since the 1980s and all he has is the Time-Sert M11X1.5mm block repair for the NORTHSTAR engine. He told me I could use that if I wanted ONE LARGER HOLE in the block and a different head bolt. I declined the offer. He agreed it would be a 'micky mouse' job to try to 'bodge' the head together like that.
bob gauff
bob gauff
jagdohrman
07-09-2017 04:26 PM
