What adhesive to use?
It should have 4 integral plastic clips, sounds like yours are broken. I wouldn't glue it. You can get an oem switch for around 40-50$. If you glue it and it fails you may not be able to get it out. You could use the opportunity to put in a switch from an 01+ with the Auto down driver's side (though that switch is pricey)
jagent
09-12-2015 09:10 AM
davidladewig
09-03-2015 06:32 PM
