Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
02 jaguar x type 3.0 misfire and limp mode lean 1
Old 03-25-2013, 08:06 PM
Martin Lord's Avatar
Angry 02 jaguar x type 3.0 misfire and limp mode lean 1
i got missfire in 1 3 5 changed plugs coils checked cat all fine revs out at 3000rpms checked for leaks there is none i need help
Old 03-25-2013, 08:12 PM
Jagfixer's Avatar
Since its fully on one side check wiring harness and use a noid light on injectors to see if they are working. (available at auto part store.)
Old 03-25-2013, 08:15 PM
tryed all are firing
Old 03-25-2013, 08:22 PM
no cruise to check light flashing nev flashed befor
Old 03-28-2013, 01:21 PM
GGG is offline
Received 16,798 Likes on 12,167 Posts
Welcome to the forum Martin,
You would get a much wider response to this question from members with the same model if it was in the X-Type section. I can move it for you if you want...........
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Isoruku
06-19-2020 12:54 PM
Steve Langridge
09-03-2015 07:35 PM
EastFalk
08-29-2015 08:22 PM
swarm27
08-29-2015 07:37 AM
NorJag
E type ( XK-E )
08-28-2015 07:31 AM
Quick Reply: 02 jaguar x type 3.0 misfire and limp mode lean 1
