Reprogramming Keyless Entry
Guest
Posts: n/a
To all, this is the follow-up to the following post:
https://www.jaguarforums.com/m_16181/tm.htm
Where I had to replace the Driver Door Module (DDM), which I did, but the problem now is that the keyless entry remotes aren't programmed to the new module. Does anyone know the "sequence" to program these remotes?
I really don't want to take this issue to the dealer only to have them tell me that I need a new DDM and charge me for something I already have and isfunctioning in the first place.
Thanks in advance!
Thanks in advance!
RE: Reprogramming Keyless Entry
the ddm needs to be configured to the vehicle then the remotes have to be programmed with the dealers IDS.. hopefully you bought the right door module seeing as there is about 5-6 different ones.. shud of got a new one.. you may have security issues.. or locking issue ..
