###Eurocharged Jaguar Pulley and Tune Sale!###
#41
Received 9,005 Likes
#43
#45
#47
#48
#49
The pulley adds 30HP to the gains of the tune. Unfortunately, we do not have any dyno charts for the F type R.
#50
My last questions:
- we bought 2 Sets of Pulleys for 2 XKRs (2004 Modell)
- we bought the pulley remover
When i get that right ... we unmount the belt, remove the old pulley, heaten up the new pulley, mount it and put the belt again on.
Is the following required: ??
- replace the screw of the pulley with some new original
- using loktide for the screw
- replace the belt with some new original jaguar belt (XKR Model 2004)
- is there anything to modify? I read a lot about tensioners and that stuff
here some quote:
here some quote:
On the stock pulley the pulley slips over the snout (shaft) of the supercharger. On the 3# pulley the inside diameter of the pulley is smaller than the outside diameter of the supercharger shaft. In order to get the pulley to slip over the shaft you need to reduce the diameter of the shaft.
Search the posts on this forum and on the XKR forum for information on how to grind the shaft
#51
- using loktide for the screw I am unsure as to what screw you are referring to as these are only press on and off pulleys. If you could supply us with a picture, I would be happy to help you further.
- replace the belt with some new original jaguar belt (XKR Model 2004) Unnecessary unless belt is worn and needs replacement
- is there anything to modify? On some vehicles, the snout has imperfections in the cast. The imperfections must be smoothed down to match the smaller portion of the snout for the interior of the pulley to clear. Otherwise there is no change to the factory system. I read a lot about tensioners and that stuff
#52
#53
#54
You can pay now and that will put you in our records. You can then send the ECU in anytime after you pay and we can tune and return it ASAP! If you decide to make this purchase, please send us a PM so we can get more info!
