Mk2 3.8L Automatic Transmission fluid fill
During my short test-drive this past weekend it seemed like the automatic transmission was slow to change gear. I had an old Ford pickup years ago that did the same thing and I "cured" it by adding transmission fluid.
There does not seem to be a convenient tube sticking up out of the Jaguar's transmission like my old Ford and I don't see it in the manual. I have a Borg-Warner(BW) auto transmission.
Where/ how do you top off the transmission fluid in my LHD 61 Jaguar Mk2?
The early MK 2 Borg Warner (such as this 1961 car) has its dipstick and fill point in the cabin, under the console carpet area (see your owner's manual for exact location). Later cars, such as my January 1966 car, have a normal dipstick and filler tube on the right side of the engine.
I have seen people recommending F-type fluid. Sound right to you?
This is the vent for the brake servo, not a dipstick.
Page A.23 of service manual shows the dipstick to be under the console in front of the radio under a circular rubber cover plate, basically it shows it's under the ash tray on early cars
Grazie mille!
This is a hilarious thread, but not very helpful. I am not good at pasting links, but try googling "Valve Chatter MK2 service manual". Open the manual, and look at page A-8.1. It shows a picture of the dipstick behind the brake bleeder you pictured, below the two radiator hoses. Should be right above where the brake lines intersect on the fender wall. It gives instructions on how to check it- engine at normal idling speed, etc. That should fix you up!
Yeah, not my first choice when I started searching; it just sorta happened. My other 2 vehicles are manuals.
Hopefully this is all a bit clearer and the offending dipstick can be found !
SoCalClockDoc (08-17-2022)
This is for the later models, the page is actually A-S.1 (fig 19) (if my glasses are ok!) which is the supplementary information and shows the later dipstick position, on the early cars it is under the center console page A 23 (fig 17) as per my earlier post (#12)
When I feel like I've found it I will take some pics.
Thank you all for your help. We will get this beauty running soon!
TilleyJon (02-24-2017)
