windscreen wiper motor
Old 06-18-2016, 01:20 AM
loftymk1's Avatar
Default windscreen wiper motor
my wiper motor makes a lot of noise it only has one speed but ther are wires not conected next to it so this is proberly the problem are they rebuildable or can you buy new is the a modern alternative
Old 06-20-2016, 03:50 PM
TilleyJon's Avatar
Hi
You should have a Lucas DR1 wiper motor I believe, here is a link to some info on that motor Motor
You can get new gears, brushes, armature etc from ebay, a guy called Steve Hunt specialises in that sort of stuff, he goes under shop name tankard03, or search Lucas DR1 on ebay and you should find him.
loftymk1 (06-20-2016)
Old 06-21-2016, 12:34 AM
primaz's Avatar
Default you might check this wiper upgrade...
Wiper Kit - CLASSIC MOTOR CARS
loftymk1 (06-21-2016)
Old 06-26-2016, 03:27 PM
BSM's Avatar
BSM
BSM is offline
The correct wiper motor is a Lucas DR3
Bruce
Winchester MA
loftymk1 (06-26-2016)
Old 06-27-2016, 08:00 AM
Jagfixer's Avatar
MK1 has DR1 wiper motors, the MK2 starts with the DR3. MK V11 has DR1, but the 140 has a different wipe of 90 deg and has to be regeared and cannot be use on MK1 or VII. I have 2 DR3s, one is 2 speed and second is 3 speed with a special park switch, both for MK2s only. I can only assume Lofty's username says he has a Mark 1.
Old 06-27-2016, 10:30 PM
loftymk1's Avatar
thanks to everyonefor your help i have a 64 mk2,,,, but looking at the electric motor part of the wiper unit it is totally round the pictures i see the dr3 is partially round with a flat side i have not taken it off to see whats stamped on the bodywork side yet
Old 06-28-2016, 04:59 AM
loftymk1's Avatar
just discovered this wiper motor is from a s111 xj6 or 12 great fit just got to find the noise problem
Old 07-01-2016, 03:44 PM
Doug Dooren's Avatar
Lofty, I'm responding to your PM here to post a picture of a S3 motor opened up. Removing the cable is simply a matter of removing the cover and then removing the drive arm which is attached via a circlip. I fit my S3 motor to an XJR wiring and control scheme, so I'm not sure what's needed to adapt it to the Mark 2 harness and switch. I'd think all of these motors would have a lead for high, low, park switch and ground, though the ground might come from any number of sources.
I had a harness and switch that came with a S3 motor upgrade kit I purchased for the Mark 2 - pretty sure I pitched these as something I'd never use, but will give a look this weekend. As you mention it included a replacement toggle switch for the Mark 2 along with a relay and harness - plus a wiring diagram for hooking up the S3 motor. I'll let you know if I find anything.
loftymk1 (07-02-2016)
sdcone04364
04-26-2016 10:37 PM
Wilfred88
04-14-2016 02:10 PM
Roger Mabry
04-11-2016 07:38 PM
Roger Mabry
04-11-2016 08:53 AM
AW2Jaguar
17
04-06-2016 11:26 AM
Quick Reply: windscreen wiper motor
