2000 Jaguar S-type V8 4.0L won't start weird noise when cranking
Old 04-20-2014, 05:19 PM
bmob222's Avatar
Exclamation 2000 Jaguar S-type V8 4.0L won't start weird noise when cranking
HI, I have a 2000 Jaguar S-TYPE V8 4.0L.
The car seems like it's trying to turn over but it just keeps making a weird sound(zzeehuuuuuuuuuuu), like something is stuck or something.
I was thinking maybe the Starter?
The battery seems to be working fine the horn,radio,lights work perfect
any thoughts?
WON'T START WEIRD NOISE WHEN CRANKING.
Old 04-20-2014, 05:27 PM
police666's Avatar
are you sure its not cranking ? could it be bore wash ? that makes an engine crank faster and sound different.
Old 04-20-2014, 05:42 PM
bmob222's Avatar
How do I check that? It sounds like it is cranking like repetitively?
Old 04-20-2014, 06:54 PM
police666's Avatar
is the serpentine belt moving as you turn the key ?
if it is bore was, basically fuel rich mix left in the cylinders when switched off gets past the cylinder rings and washes the oil from the cylinder walls (hence bore wash) this means it can't build any compression in the cylinders as it is the oil with the rings that makes the seal.
It most commonly happens when the engine has only been running for a few minutes from cold then switched off.
With no compression it won't start and turns over more freely due to no compression. (making it sound like the starter is not engaging)
The good news is its not broken.
To start it you need to turn it over with your accelerator pedal flat to the floor, this is known as wot (wide open throttle) when at wot NO fuel will be fed to the cylinders allowing the oil to recoat them and the rings.
The bad news is it can take 50+ tries
Only turn it over for 15 to 20 seconds at a time making sure the accelerator is flat to the floor. Let it rest about 10 seconds between turnovers.
After a while you will hear and feel it start to catch and cough, when this is happening have the accelerator pedal 3 quarters of the way down and it should catch.
You might want to fully charge your battery.
The other way round it is to remove the coils and plugs and squirt a big table spoon of oil into each cylinder, I have not had to do that as I have found the cranking with wot works.
bmob222 (04-21-2014)
Old 04-21-2014, 02:07 PM
bmob222's Avatar
Thanks so much it worked. After having my jag sit for 6+ months she started up. It feels good to hear her purr again. Thanks so much!!! Now only if i can figure out why she goes to the right when driving at 60+ she would be perfect.
Thanks Again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-22-2014, 11:28 AM
police666's Avatar
im glad i could help.
you probably need a wheel alignment but get underneath first and check nothing obvious is wrong.
this video will help you
http://www.mediafire.com/watch/b7yaj...ises,_Loos.mp4
download it rather than stream it
Old 07-23-2014, 11:09 PM
gzuskid's Avatar
Talking wot crank works
[Hello, I wanna say thanks to police666. I was having the same problem with my jag. It would only click when I tried to start it after it set for about 8 months. I was about to have a new starter installed so As a last resort I tried the advice that you gave to someone and it worked. It took me maybe 25 tries.Thank you so so much for that info.
QUOTE=police666;958834]is the serpentine belt moving as you turn the key ?
The other way round it is to remove the coils and plugs and squirt a big table spoon of oil into each cylinder, I have not had to do that as I have found the cranking with wot works.[/QUOTE]
Old 11-16-2014, 07:57 AM
Big2K's Avatar
Default Compression Lost
Once a Jag has lost compression. How do you 'rebuild' that compression?
Thanks!!
Old 11-16-2014, 09:17 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
Basic ideas:
1. do not add more fuel (*)
2. do add oil
(*) washes oil away and also once flooded the engine won't start as the mixture is far too rich
For #1 if you crank then you also need WOT (see my sig).
For #2 you either remove plugs and add oil or crank multiple times till oil seeps and smears where it needs to be. You may need to recharge battery. Don't crank for too long without short rests or you may burn the starter motor out.
Read threads on
bore wash
bdboyle
09-16-2019 05:58 PM
n2audio
17
10-09-2015 10:53 PM
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
UKnFor-dluv-expat
09-26-2015 08:40 PM
Quick Reply: 2000 Jaguar S-type V8 4.0L won't start weird noise when cranking
