Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > S-Type / S type R Supercharged V8
Sign in using an external account
Register Forgot Password?
Search
S-Type / S type R Supercharged V8 1999 - 2008
Sponsored by Simple Tire
Click Here
LinkBack Thread Tools Search this Thread
Old 01-31-2009, 09:42 PM
Default 2002 S-Type... No spark plugs? Where are they?
I bought this S-type about 2 weeks ago now. Had it in the shop for transmission repairs for about 4-5 days.
Got it back two days ago. Today I changed the oil, oil filter, air filter and cleaner the Mass Air Flow Sensor today.
I want to change the spark plugs but I could not see the. I have the 3.0L V6. Where are the plugs? What do you have to take off to get to them???
Thanks. Greg
__________________
New to the Jag world with tears in my eyes....
Old 01-31-2009, 10:01 PM
carelm's Avatar
Default RE: 2002 S-Type... No spark plugs? Where are they?
Hi Greg,
The spark plugs are under the ignition coils. Recommend you download the JTIS manual for specific instructions on procedures. Go to the General Tech Help forum and go the Christo's JTIS Download site message.
Mike
__________________
2005 S-Type Zircon 3.0 V6
2001 Audi A6 Avant Ming Blue Pearl 2.8 V6
Rotating Jaguar Pictures
Old 02-01-2009, 07:38 AM
Thanks. I have the JTIS. I just was surprised I could not even see the spark plug wires running somewhere... Figured it was a magical engine!
It looks like a little work to get to them, but doable.
Are there any DANGERS or things easily broken to be aware of on theway in there? Do you suggest changing out anything else while I am elbow deep in there?
Are there any electronic manuals out there that have better (actual) photographs of the S-type for service? Which would you suggest?
Thanks. Greg
__________________
Old 02-01-2009, 10:33 AM
Brutal's Avatar
Photobucket
BILL BRUTON
the biggest thing to watch out for as far as breakage are the T coolant fitting on top of the engine, if it breaks use a vacuum T and hose clmaps to repair, no reason to but the hose assembly. Also the small hose that goes to the to radiator and thermostat pipa assembly. This small pipe barb breaks if you look at it wrong, I you have some mileage, and assuming you do since it came from the trns shop, just go buy that hose assembly from the dealer. Comes with all new hose assembly and thermostat, that way if you break it youll be ready, and if not(you wont if you already have the part) youll be replaceing a maintenance part now anyway
__________________
WORKING TO SUPPORT THOSE THAT ARE NOT EVERYDAY
Old 02-01-2009, 01:15 PM
Quote:
ORIGINAL: BRUTAL ....have some mileage, and assuming you do since it came from the trns shop,
It has 78K on it... is that a lot for these cars? The 4-3 solenoid C spring broke on it...
Quote:
...just go buy that hose assembly from the dealer.
The nearest Jag dealeris 80 miles away. Would a Ford dealer have the hose assembly? Autozone? [sm=americanasmiley.gif]
Thanks, Greg
__________________
Old 02-01-2009, 02:53 PM
Real_Tech's Avatar
Photobucket
The hose BRUTAL is talking about is just brittle, mileage hardly seems to matter. The dealer is probably your only option, it is cheap though $25 if memory serves. You could also pick up the inlet manifold o-rings at the same time though I see them reused a lot with no problems. Whetever you do make sure you put the crash bracket back on the back of the inlet manifold. I'm attaching pictures of what happens without that bracket.
[IMG]local://upfiles/6177/7559B38751EE433CA8AA1466B70DC3D4.jpg[/IMG]
__________________
I cannot see through steel.
I cannot predict the future.
I cannot sh*t parts.
Old 02-01-2009, 02:58 PM
Real_Tech's Avatar
Photobucket
Here's 2 more photos of what happens without the crash bracket.
[IMG]local://upfiles/6177/9140C18D31C14AD88DFF23AF0511F95C.jpg[/IMG]
[IMG]local://upfiles/6177/144B529EA65E4F48BE97721DE602E389.jpg[/IMG]
__________________
Old 02-01-2009, 08:26 PM
Real Tech,
That loks like something I would not wnat to happen. Got a picture of what the "Crash Bracket" looks like so I do not forget to put it back?
I'm assuming those pics are AFTER a crash... ????
Thanks for the advice... Greg
__________________
Old 02-01-2009, 09:53 PM
Brutal's Avatar
Photobucket
BILL BRUTON
RT, the hose assembly Im talkign about is over a $100, the piece that breaks is the small plastic barb for the hose to the throttle body. The upper hose, pipe to thermostat, and thermostat assembly comes together. And whered you get those pics?
__________________
Old 02-03-2009, 12:39 PM
I'm not getting the photos.
I just get the following link (for the 1st photo):
Can anyone help?
Old 02-03-2009, 06:21 PM
Real_Tech's Avatar
Photobucket
Quote:
Thanks for jinxing me you evil SOB. I was doing an old rat 160k S-type today for the lower breather elbow and not only did I manage to break the nipple off of the upper radiator hose, when I breathed on the T hose nipple to the expansion tank that one snapped off too. To make matters worse I was working on the engine hot and I clamped off the hoses for the manifold/throttle body so that when the upper rad hose nipple broke off, the fuel rail was off and a stream of coolant blew into all the ports on the drivers side head. I had to take the sparkplugs back out that I just put in to remove the coolant from the cylinders. Just goes to show you this sh*t can happen to anyone.
__________________
Old 03-12-2011, 02:14 PM
we cant see your pics
Old 12-15-2011, 12:54 PM
Virginia Hughes
Guest
Posts: n/a
Default Jag S type spark plugs
I have a 2000 Jaguar S type v6. Do you have to completely uncover the right side of the engine to access the spark plugs? Thanks
Old 12-15-2011, 02:45 PM
Brutal's Avatar
Photobucket
BILL BRUTON
yes you have to remove the intake and replace both upper and lower intake gaskets(these on this models are NOT reuseable, they leak real easy) and replace the lower breather hose while in there to. Its a 90* below the lower intake manifold that houses the injectors towrads the back of the engine
Tags
2002, change, changing, jag, jaguar, locate, location, plug, plugs, real, spark, sparkplugs, stype, type, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
