Anyone have a guideline on how to bleed the coolant system on the STR's??
Old 04-29-2012, 03:23 PM
jag79's Avatar
Default Anyone have a guideline on how to bleed the coolant system on the STR's??
Is there a certain guideline to follow to bleed the coolant system of our STRs from air being trapped in? I know theres the bleeder screw to release the air and also you have to turn the heat on max, but other than that is there something I should know to help make this process of bleeding the air out completely so I won't run into trouble down road after having a new expansion tank replaced? Any help would be appreciated!
Old 04-29-2012, 07:03 PM
searanch's Avatar
Remove S/C bleeder screw. Fill system with coolant/distilled water while paying attention to the open bleeder. When coolant starts coming up the threads of the open bleeder replace screw. Be sure that the bleeder is open on the expansion tank at the same time as fill. Close expansion bleeder.
Start engine and turn up full heat. Run until engine warm keeping an eye on the expansion tank. Let engine cool down. Top up coolant.
Dead simple.
This advice is worth exactly what ya paid for it...
The following 2 users liked this post by searanch:
jag79 (04-29-2012), TM08XKR (04-01-2022)
Old 04-29-2012, 08:33 PM
jag79's Avatar
Dead simple.
Muchos Gracias!
Old 04-29-2012, 08:57 PM
Michael Star's Avatar
Something I try to do is park on an incline so the front is the highest part of the car, sometimes helps to get rid of stubborn bubbles in the system.
Jumpin' Jag Flash (12-27-2014)
Old 04-29-2012, 09:32 PM
clubairth1's Avatar
Received 2,217 Likes on 1,754 Posts
Also check the level over the next several days. I have found it will work the bubbles out by the heat and cool cycles. I always have to add some small top up amounts.
Old 12-25-2014, 10:17 AM
Wuzupez's Avatar
Where is the s/c bleeder screw located?
Old 12-26-2014, 11:10 AM
On the expansion tank. Looks like a phillips head (but plastic)
Old 12-27-2014, 09:25 AM
Wuzupez's Avatar
From what searanch was talking about there are 2??? The s/c bleeder which I've never heard of and the expansion tank one which you are correct about! My expansion tank bleeder screw is seeping. Not sure why? Any ideas?
Old 12-27-2014, 09:53 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
The S/C circuit never seems to need separate bleeding. (Forget it unless you are sure you need more info in which case go hunting in JTIS.)
With the weeping you describe either you figure a fix (gasket? something else?) or I suppose replace the part.
Wuzupez (12-27-2014)
Old 12-27-2014, 10:35 AM
Wuzupez's Avatar
Anyone know if the the bleeder screw on expansion tank has an o-ring or gasket?
Old 12-27-2014, 04:33 PM
Received 1,420 Likes on 1,063 Posts
I have a 04 XJ8 - I just recently replaced my expansion tank as a precaution (the old expansion tank, while aged was still good)
I took the bleeder screw out and looks like there is an o ring at the base of the plastic screw.
Old 01-17-2015, 08:19 AM
janesjag's Avatar
where's the expansion tank bleeder?
Old 01-17-2015, 08:35 AM
on top of the expansion tank - 03+ S Type, for 00 to 02 the bleeder hose is tucked between the master cylinder and valve cover.
Old 01-17-2015, 08:54 AM
janesjag's Avatar
Thanks. It's a 2001 S-type 4.0L
abonano (01-17-2015)
Old 01-17-2015, 11:34 AM
you will need to find the bleeder hose by the master cylinder tucked away - it has a plastic cap that screws out. The plastic and hose should have a yellow "alignment" Mark. If it doesn't - before unscrewing draw a mark.
This is to ensure you don't over-tighten that fitting. It is prone to cracking requiring replacement of the entire expansion tank.
Use a flat blade thick screw driver and unscrew carefully until a steady stream of coolant comes out then tighten to the alignment Mark - no further...
Have you serviced your cooling system recently? This would be the only reason to "bleed" the cooling system in this fashion..
Old 01-17-2015, 03:19 PM
janesjag's Avatar
Sorry. I got called away. Am I doing this with engine running at op temp or cold, engine off?
Old 01-17-2015, 11:50 PM
running with heater on max heat.
alljaguars
02-18-2024 04:53 PM
Remnant1
06-20-2022 08:29 PM
dotcom
09-12-2020 01:43 PM
BKSinAZ
02-20-2015 02:55 PM
LeapingCat
10-02-2013 04:47 PM
Quick Reply: Anyone have a guideline on how to bleed the coolant system on the STR's??
