coils n plugs not problem on the P0305 code.
Old 12-17-2012, 10:43 AM
Eman_usa's Avatar
Default coils n plugs not problem on the P0305 code.
Wanted! a solution for P0305 cyl #5 misfire.
Ive replaced the coils and put new plugs in my 2002 3.0 s-type.
that did not resolve the issue.
Old 12-17-2012, 11:46 AM
Jon89's Avatar
Received 4,275 Likes on 2,812 Posts
Consider changing your Intake Manifold Tuner Valve O-rings (IMT O-rings for short). Remove the factory yellow-colored O-rings and replace them with the new-and-improved green-colored O-rings (there are a total of two). Should cost you less than $5 if you do it yourself, and there are several good DIY threads here that will walk you through the process step-by-step. Just search for "IMT O-ring replacement" here on the forum and you'll find what you need....
Eman_usa (12-19-2012)
Old 12-17-2012, 12:00 PM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
While changing coils, did you replace both upper and lower intake gaskets? Also the rubber elbow under the lower intake should have been replaced at the same time.
Old 12-17-2012, 12:38 PM
Received 1,420 Likes on 1,063 Posts
To add to the valuable advice already provided above - check to ensure the connectors to each fuel injector (especially cylinder #5) is snug and tight - as a loose connection at the injector can flag a misfire code. Those plastic locking tabs on the connectors are notorious for snapping/breaking off...
Old 12-19-2012, 09:51 AM
Eman_usa's Avatar
Thanks everyone,
This is great information.
Today i will be checking and/or replacing #5 fuel injector on passasenger side rear.
Then i will locate and replace the rubber elbow. also the o-rings have already been replaced when i did the coil and plugs..... wish me luck!
also i will be cleaning out lines and looking for any breaks cracks.
thanks,
Eman
Old 12-19-2012, 10:06 AM
Eman_usa's Avatar
hello, thanks for the info on the gaskets.
I just wanted to add, when the misfire happens it is only around 1500-2000 rpm's. and only when the vehicle gets warmed up. any idea's.
thank's,
Eman
Old 12-19-2012, 10:38 AM
Eman_usa's Avatar
hello there,
I know of the upper intake gaskets but.... what? lower was never taken off.
Haaa?
Old 12-19-2012, 11:38 AM
joycesjag's Avatar
Just 4 more bolts remove the lower intake and right below it is the infamous elbow that cracks and needs to be replaced.
This should help:
Jaguar HELP!: Intake manifold in a 2002 S-type 3.0L
Old 12-19-2012, 12:14 PM
tbird6's Avatar
Did you replace all the coils and all the plugs?
It's a false economy to try and do them one at a time. On the V-6 it's easy to do one side, the other side is harder. Since you are unaware of the intake gasket issues I think you only replaced the easy side.
Old 12-19-2012, 03:35 PM
Eman_usa's Avatar
ok, today i replaced the #5 cyl fuel injector ( passenger side rear near firewall) and cleaned and checked the hoses and lines for leaks.
I took off lower intake (it was very easy with fuel rail.
then i took the elbow off. that was in great shape no problems.
cleaned and checked all other injectors and o-rings.
lets see what happens.
Eman
Old 12-19-2012, 04:01 PM
tbird6's Avatar
Have you changed all the coils and plugs? I still can't tell??
Old 12-19-2012, 04:30 PM
Eman_usa's Avatar
no i replaced the harder side(passenger side) that is needed to get to cyl #5 correct?
Old 12-19-2012, 04:53 PM
Cylinder numbering changes on model. What model is the car X200 or X202
Pre 2002.5MY X200 cars cyl 5 is LH side midle cylinder, Drivers side if you are left hand drive in USA.
2002.5MY onwards X202, cyl 5 is rearmost cylinder on the RH side of the car. Passenger side in the US.
Old 12-19-2012, 04:55 PM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
Er... is your VIN before M45255? Where #5 is depends on the VIN, as the Vehicle Specs PDF & JTIS in the stickies say.
(That's the VIN break for 2002.5MY Europe, 2003 USA)
Old 12-19-2012, 05:00 PM
Eman_usa's Avatar
that may be the problem i went out and checked the date it is 9-01 so do you think i changed the wrong one?
that would be the easy side.
thanks, Eman
Old 12-19-2012, 05:08 PM
tbird6's Avatar
That was my point!
At your car's age and mileage you need to change them all. They are wear items and you might get by for several months until the next coil breaks down. But you are just dragging the problem out. It won’t go away.
Old 12-19-2012, 05:11 PM
Eman_usa's Avatar
Yes i have a left hand drive USA model with the date code of 09 of 01 that is a pre 2002 model year i was going off my dealer info.
could someone confirm the cyl#5 is on the drivers side i would have easily repaired the issue.
haha that would be great. no sense crying over spilt chocolate milk.
Old 12-19-2012, 05:33 PM
Its the midle one on the easy side.
swap it with the one infront if you dont believe me, misfire will jump to cyl 4.
PAGE 14
https://www.jaguarforums.com/forum/a...-spec-book-pdf
Eman_usa (12-20-2012)
Old 12-19-2012, 05:50 PM
JagV8's Avatar
In future use the VIN not the date.
Old 12-19-2012, 06:39 PM
joycesjag's Avatar
It wouldn't be the first someone "split" the chocolate milk here.
Quick Reply: coils n plugs not problem on the P0305 code.
