Fault Code P0065 - 2000 S-Type 4.0
Old 07-11-2012, 10:54 PM
jjohns26's Avatar
Question Fault Code P0065 - 2000 S-Type 4.0
I got a P0065 (Air assisted control range/performance) code today. Honestly... not really sure what that means! I've done some searching and everyone seems to have their own opinion on what to do/check/fix, etc. I guess I'm wondering if there is a certain order in which I should be testing, replacing, etc.
Any feedback would be greatly appreciated as I dont want to do any unnecessary work if I dont have to!
Old 07-12-2012, 01:23 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
I'd use Jaguar's data, such as the codes PDF (in FAQs and JTIS).
Only the earlyish V8s have the device.
Old 09-12-2012, 01:44 PM
usajay38's Avatar
Default p0065
my 2000 4.0 has now come up with the same code. Does anyone have a picture of the air assisted injector and its location? I took a picture of my engine and maybe someone could point it out to me.
thanks
john
http://i282.photobucket.com/albums/k...r/SANY0541.jpg
Old 09-12-2012, 03:47 PM
Received 1,420 Likes on 1,063 Posts
thanks
john
Located ajacent to the throttle body on the engine.
That code P0065 for the air assist injection is usually due to a faulty valve located on the intake. If the valve is ok and the tubes are not clogged then it is a problem with the throttle body assembly.
[/COLOR]
The following 2 users liked this post by abonano:
JagDiva (03-30-2018), usajay38 (09-12-2012)
Old 06-14-2014, 11:44 AM
moranlr's Avatar
[/COLOR]
I have the same problem with my 2001 S-Type 4.0.
I removed the AAI valve and it looked clean. How do I tell if the valve is OK?
I can't find this part at any auto parts store. Jaguar told me they could get a used one (probably from a junker). Any thoughts?
If the problem is in the throttle assembly what do I do?
Attached Thumbnails Fault Code P0065 - 2000 S-Type 4.0-2009-09-06_184200_104411153.gif
Bcrary3
09-12-2021 05:41 AM
skadmiri1
09-09-2015 11:27 AM
stype40
09-09-2015 08:14 AM
pocketrocket
09-03-2015 07:44 PM
Bowman
09-03-2015 03:17 PM
Quick Reply: Fault Code P0065 - 2000 S-Type 4.0
