Steering Wheel Alignment
Old 05-11-2011, 05:13 PM
maxthrottle's Avatar
Default Steering Wheel Alignment
OK.
Got the 03 STR back this week. AC Compressor replacement, and Spark Plugs/Valve cover gasket replacement.
The AC compressor replacement required dropping the steering rack, removing the engine mount and raising the engine. Now the steering wheel is not perfectly centered when driving down a straight road, it's off to the right maybe 5-8 degrees. The car tracks nicely and nothing else is wrong except the darn steering wheel is just leaning ever so slightly to the right! I told the mechanic about this and he said that's what happens when the engine mounts and steering rack is dropped. He said the alignment is what it was before, (just aligned 2 months ago when new tires and rims were fitted) he could center it again but it would take another $80 front end alignment.
Is there a simple adjustment to tweek the wheel back to center?
Thanks,
Cheers.
Bob
Old 05-11-2011, 05:24 PM
ChrisSTR's Avatar
It would be safer to put on the alignment rack end, but I'd guess you could DIY if you unlock the tierod adjustments and tweak the nut; make sure the wheel is dead center, and tighten it back up when your satisfied.
^ This advice is worth exactly what you paid for it.
Old 05-11-2011, 05:30 PM
I'd like to try it, I think a turn or two would do it.
Not sure where the tie rod nuts are.
What is the proceedure?
Thanks,
Cheers.
Bob
Old 05-11-2011, 05:57 PM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
Bob, the mechanic may have unbolted the steering coupler down by the rack, should have been done according to alldatas procedure for raising the motor. The mechanic when reconnecting did not get the rod matched up, fairly easy to fix if thats what happened and the belly pan is off.
Old 05-11-2011, 06:11 PM
Yep,
that's what I was thinking looking at the proceedure from the .pdf.
I dont think they removed the belly pan, but I was not there supervising the repair, (they would charge double for that!) I think they got at everything from the left front tire well. I think you can access this steering link from there.
Might have been put back together off one spline?
Loosen, go back one click and tighten?
Could be worth a try.
Thanks,
Bob
Old 05-11-2011, 06:16 PM
joycesjag's Avatar
Thats the other way of accessing the coupler. Good luck.
Hopefully this time I did not "steer" you wrong !!
Old 05-11-2011, 07:47 PM
Thanks Rick,
I always appreciate your advice.
I'll give this a try this weekend.
Bob
H20boy
07-23-2021 09:39 PM
PMKimpton
08-03-2019 08:22 PM
RobertTheBloke
09-24-2015 11:48 AM
Burdedw
09-12-2015 10:39 AM
1964Daimler
09-09-2015 11:28 AM
Quick Reply: Steering Wheel Alignment
