Gearbox Fault and code P1388
Old 05-14-2010, 11:48 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Good deal for someone with a V8!
  #42
Old 05-14-2010, 12:35 PM
Mafioso's Avatar
Do they use the same coils? just 2 less?
  #43
Old 05-14-2010, 01:27 PM
Received 2,183 Likes on 1,355 Posts
Damn since no one wants to touch the vvts codes again. Your most likely issue(especially since you mentioned after oil change) is vvt oil starvation. In other words there is just not enough oil pressure remaining in the oil galleys to "properly" function the vvts. It being lost throughout the engine on bearing clearances that have opened up and bleed off pressure. think of it like this. if you stand a hose up straight with no holes and run water through it it comes out the other end fine. But as you start poking holes in the hose the water on the other ends drops and drops as you create bigger/more leaks in the hose. This is what wearing bearing clearances do. they allow more and more oil pressure to bleed off, not enough to cause oil pressure warnings, especially since the oil pressure sender is down low on the block and early in the oil system by the pump and filter
Try changing to 20-50w oil
  #44
Old 05-14-2010, 01:43 PM
JagV8's Avatar
Is that for P1788 reported by thehedge?
Isn't P1788 a gearbox code?
  #45
Old 05-14-2010, 02:20 PM
thehedge's Avatar
Mafioso, thanks, but my understanding is that they are different coils for the V6.
BRUTAL, (again, excuse the lack of knowlege) since my oil was just changed less than 200mi. ago w/full synthetic and filter, is that necessarry NOW, or at the next oil chg? Or, can I get away with adding the lucas synthetic stabilizer to thicken it up?
jagv8, P1788 is "Pressure Control Solenoid "B" Open Circuit". My MIL does however, display "gearbox fault"
  #46
Old 05-14-2010, 02:24 PM
yes wait till next lof, but do lucas for now and see what happens. Ive always gotten great results from lucas products. remember we run about 8qts oil cap. so you might need more than 1 container.
  #47
Old 05-14-2010, 02:40 PM
thehedge's Avatar
I have certainly appreciated and taken into consideration ALL advice/recommendations, so thus far, the jag tech is replacing ALL 3 coils on bank 1 (intake manifold side) with the recommended Bosch coils, and ALL the plugs with the NGK iridium’s vice Autolite platinum, new O-rings, gaskets, and then vacuum tubes, PCV as needed/once they remove manifold.
For the P1788 (Pressure Control Solenoid "B" Open Circuit) he said he can go in, and replace the spring for about a grand, but wants to wait until 1st set of problems corrected/cleared to see if it comes back...I don’t know, but I do trust the guys ability, and it seems to make sense to me…
  #48
Old 05-14-2010, 02:43 PM
thehedge's Avatar
I am certain they put just over 6 quarts in...the car is with the tech, but the last time I checked the stick it appeared fine?!?
  #49
Old 05-14-2010, 03:08 PM
JagV8's Avatar
Help! I'm lost
Who has any VVT codes now (and what code(s))?
  #50
Old 05-14-2010, 07:38 PM
thehedge's Avatar
Sorry jagv8, not me....err, well, at least I don't think its me....yet...
Originally Posted by jagv8
Help! I'm lost
  #51
Old 05-15-2010, 12:01 AM
Help! I'm lost
P1388, early on and trying to get rid of with reflash of ECU with TSB
  #52
Old 05-15-2010, 03:02 AM
JagV8's Avatar
Yeah but they were the false-flagging DTCs and have gone with the reflash. Now he has a misfire (P0303) and gearbox (P1788), doesn't he?
Shouldn't he fix those now? Changing his engine oil isn't going to help his gearbox is it?
  #53
Old 05-15-2010, 03:31 AM
Leedsman's Avatar
I thought there was something about you I liked, Hedge. Over here the word is tightarse though -- hence the gags about talcum powder and squeaking.
Leedsman.
  #54
Old 05-15-2010, 11:55 AM
thehedge's Avatar
lol...Thanks Leeds!! ...and to think I was a bit uncomfortable being the tightest-arsed jag owner on this side of the pond!!! Its certainly nice to feel welcome…
  #55
Old 05-16-2010, 04:35 PM
jklit's Avatar
my suggestion would be to find a good local mechanic who won't charge you $120 an hour like the jag dealerships. their advice is to replace everything. i found a local european car specialist who took apart both banks and replaced coils, plugs etc., he also agreed, and as we found out there were a few after market coils that seemed to be failing, if you do go after market find an OEM part, or most local parts stores sell jag parts (many similar to the lincoln ls, and some common to other ford cars), still certain things you have to get from the dealer unfortunately.
i would suggest this website, their coils and parts are legit, i know first hand, also got parts of the suspension here as well....they are the cheapest i've found...
http://www.welshent.com/
if you can find a reliable local mechanic, they would probably be much more willing to use parts that you request, however without guarantees...
  #56
Old 05-17-2010, 08:49 AM
I just went back and reread posts. I didnt see anywhere that he said p1388 VVT codes are gone. And I seriously doubt it is false flagging this late in the game. Another owner tried the reflash tsb and said they were gone for awhile then returned, and the reason for poor running after the reflash was done is probobly cause the engine and trans control modules adapt to running/driving conditions over time. poor injector spray patterns, dirty air filter, lower compression, driving style, small vacuum leaks etc... This is 1 of the priorities of OBII that it is able to abadpt and maintain acceptable emmissions, performance and economy. When reflashing an ecu these adaptaton are wipped out and the base parameters are now back to zero. So what was being masked before by altered fueling, ignition is no longer.
On the TSB the only thing they could change/done wrong, is wether the engine number is in a given range which gives a more agressive software change...dont ask me what I didnt write the software.
no I didnt say a p1788 shift solenoid could be fixed by changing the engine oil its a trans valve body issue. I would change that solenoid in the valve block , the fluid and filter or keep on going.
95%(a number I pull from behind me, but none the less close) of VVT faults now days are oil supply related.
  #57
Old 05-17-2010, 09:05 AM
JagV8's Avatar
Yeah, I had to re-read too
But in this he says he has no VVT codes so they must be gone:
Help! I'm lost
But he does have the P0303 misfire #3 and gearbox P1788 codes.
  #58
Old 05-17-2010, 03:21 PM
thehedge's Avatar
jagv8/Brutal, the car is still with the tech, and I am (now) not at all certain as to the actual status of the P1388 VVT codes, as he has not actually said what codes were, or, were not showing, he just felt it was particularly important to get the misfire corrected immediately before moving on. The dealer (obviously) did not list or mention it either AFTER the reflash, but in a letter stated that the update they did was "several generations ahead of the S303-09".
Geeze Brutal, I don't believe I had read that in any posts here before now! Perhaps it has been said, but maybe not so plainly, however, I do wish I had that bit of knowledge; “I seriously doubt it is false flagging this late in the game…” before they did it, and just focused on the misfire, etc…Did I just waste $200 on top of everything else, or was it just premature, or, ?!??
None-the-less, I am hoping to get the car back today, but fear I may need to corner the US talcum market, as I have not heard from them today, and that can only mean, ITS GONNA BE PAINFUL!!
  #59
Old 05-17-2010, 05:27 PM
HEDGE I TRY NOT TO MAKE PEOPLE FEEL LIKE THEY SPENT MONEY NEEDLESSLY, AND i DONT FEEL YOU DID(MAYBE PREMATURELY) THERE HAS BEEN A ECU/TCM RECALL GOING ON WITH JAGUAR THAT INVOLVES REFLASHING THE ECU AND OR TCM. YOU KNOW THE WINDOWS POPUP THAT SAYS "UPDATES AVAIL, UPDATE NOW?" WELL THATS WHAT YOU GOT, THE LASTEST AND GREATEST SOFTWARE CHANGES TO ADJUST/FIX/MODIFY THE OPERATION AND RUNNING OF YOUR CAR. ITHINK THE $200 WAS STEEP, BUT EVERY DEALER CHARGES DIFFERENT THINGS. DEPENDING ON MARKET, LOCATION ETC... HELL I CANT GO TO 2 OF THE SAME GROCERY STORES AND PAY THE SAME THING ON THE SAME ITEMS.
AS CARS GET OLDER I REALLY TRY TO TALK TO CUSTOMERS AND EXPLAIN WHY AND WHAT SHOULD BE DONE NOW AND THEN LATER. IN A SITUATION LIKE VVT CODES, I WOULD OPT FOR THE OIL VISCOSITY CHANGE. WHY, ITS WORKED MANY TIMES BEFORE(EXPERIANCE) YOU NEED OIL CHANGES, AND ITS CHEAP IN THE OVER SCENARIO OF THE PROBLEM. YOU CAN ALWAYS SPEND MORE LATER...
I MEEN YOU DONT GO TO THE DOCTOR WITH HIGH BLOOD SUGAR AND GET TOLD YOU NEED A NEW PANCREAS.....
YES MISFIRES SHOULD ALWAYS BE FIXED RIGHT AWAY CAUSE THEY CAN TAKE OUT THE CATALYTIC CONVERTORS. aND YES USEALLY THAT TRANS CODE IS A SOLENOID REPLACEMENT FIRST. I HAVE HAD TO INSTALL VALVE BODIES ONCE OR TWICE THOUGH TO FIX SHIFT SOLENOID ISSUES THAT WOULDNT GO AWAY.
  #60
Old 05-17-2010, 07:23 PM
thehedge's Avatar
EASY Brutal!! I truly meant no disrespect to you (or anyone), nor was I in the least bit upset about what you had to say, or, trying to place any sort of blame…in-fact, I am SINCERELY grateful for the ideas, information (although sometimes a bit above my head), and suggestions, that you, jagv8, Leedsman, and ALL, have generously provided me with to see this through properly, and thereby also giving me a basic understanding necessary in resolving these issues with my jag. The way in which you had explained it had actually made much more sense than what I previously understood! So, perhaps more than anything, my jocularity (due to being overly tightarsed) overshadowed what should have been gratitude and discretion under the circumstance...
Quick Reply: Gearbox Fault and code P1388
