HELP! Clearing flooded S
Old 05-18-2008, 09:16 AM
conipc's Avatar
Default HELP! Clearing flooded S
I know there is a procedure to use when the car is flooded (other than removing all plugs)..please help!!
Old 05-18-2008, 10:23 AM
conipc's Avatar
Default EDIT--revised post
Have located procedure from searching forum--no avail. Will let it all dry out a bit. However:
Code 1339 comes up, which is supposedly secondary fuel pump (it is an R), but this would onlyaffect high-demand use, not starting and basic running. I suspect flooding or perhaps water from car wash..car cranks but no start.
Any ideas for better diagnosis?
Old 05-18-2008, 08:01 PM
conipc's Avatar
Default IT'S NOT JUST A CAR....IT'S AN---
adventure. Here's the story. Moved the car a few feet to wash. Wouldn't restart. Figured it was flooded or wet. Nope...Plugs clear; car sat in 88F for 5 hours,so should have dried out.1339 code related to fuel pump failure. Well, check the fuses...nope.Well, what's the first thing you do when a computer crashes? right, reboot. So, turn on the key and pull/replace all the fuses and relays related to pump. Guess what...starts right up.....
Old 05-18-2008, 09:27 PM
Default RE: IT'S NOT JUST A CAR....IT'S AN---
has check engine returned?
Old 05-19-2008, 08:10 AM
conipc's Avatar
Codes cleared. Since the car wouldn't run, there was no check engine light--none now either....
Larry-Cleveland
02-09-2019 03:17 PM
NS2000XKR
01-01-2017 10:41 AM
inactualis
10-02-2015 11:13 AM
o1xjr
10-01-2015 09:46 AM
Quick Reply: HELP! Clearing flooded S
