Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > S-Type / S type R Supercharged V8
Sign in using an external account
Register Forgot Password?
Search
S-Type / S type R Supercharged V8 1999 - 2008
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 06-29-2010, 08:58 PM
Default Help!!! Problems with my 2000 jaguar s-type 4.0
My jag check engine light came on about 2 months ago. Did a check and it said 2 cylinders missfired. After a couple days it went off. Periodically it would come on and go back off. Recently it came on and stayed on. After getting it scanned from 3 different computers i be came very confused because it gave different cylinder missfires each time. The car was running fine. Only idling badly, and sounding like a motor cycle while runnung. I change the spark plugs. Cylinder 6 missfire. And engine coils. It continued to show cylinder 6 missfire. I had the fuel injecter switched wit cylinder 2. Continued to show cylinder 6 missfire. I had a compression check done, and it passed. The car starts up and runs like a motor cycle and shakes badly when hitting the gas. It jerks and sputters. And when in idle and im mashing on the gas the care soesnt rev up like it supposed to. It does almost nothing. What could be the problem???
Old 06-29-2010, 11:15 PM
Kingjay, your 00 S-Type is going through the worn wires and plugs blues. Git them replaced and yer on ur way.
Old 06-29-2010, 11:24 PM
Bfsgross, exactly what wires and plugs need to be replaced, and how much will dis run me if yu know? Also could it really be old wires and plugs dats causing my car to make puttering noises and jerking and hold up of the engine??? Not to mention while in idle the car won't go pass 2 rpm when mashig full pressure on da gas...
Old 06-30-2010, 12:24 AM
I have the same problem.
After changing coils on one side and all spark plugs it disappeared for a while.
After 2 weeks the rpm was going up but speed not and jerking begins again.
It helps before you put on D first go on 2, feel the car shifts and then on D.
I wonder if this is transmission?
Old 06-30-2010, 12:30 AM
H20boy's Avatar
statue, I think you're on a totally different issue there my friend. If it idles and engine RPMs are steady, the car is not misfiring. You'd know it if it was. Yours is definitely transmission related.
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 06-30-2010, 06:39 AM
kingjay, apologies, I now notice you changed the spark plugs. Was this performed prior to or aft of the misfire? You still haven't changed "all" the wires. Do this since you now have new coils and plugs. Now coils and plugs are new and presumed to be performed correctly. Time for the wires...which should have been checked and replaced first. They are likely the originals and chaffe and crack, causing the spark to ground...not fire the cylinder. Check back.
Tags
2000, 40, accelerate, engine, fire, forum, jag, jaguar, jerks, misfires, miss, problem, problems, sputters, stype, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
