How do you (I) change an S-Type headlight lens?
Received 2,183 Likes
RE: How do you (I) change an S-Type headlight lens?
do you have the entire assembly or the lens only?, if the lens you pop in the oven for 10 minutes at lowest setting to heat and soften then urethane bond to separate. or are you wanting to know how to remove the bumper to remove the assembly???
ORIGINAL: BRUTAL
Pillchuk (12-30-2013)
I want to change the lens inside S-type headlamp...see some! So I want to change only the back side of the headlamp...the black plastic on the rear side of the headlamp?! That broke...front impact,back crack!!! Crazy!!! So owen? 50 degrees!? For 10min!? And then what? Just pull out the back part or the front never mind and do the same with the other good lamp!? Then,,,how to put it back,when I finish the job???
