idle problems 2003 jaguar S type 3.0l
Old 04-22-2014, 11:27 PM
bighoks's Avatar
Default idle problems 2003 jaguar S type 3.0l
about 6 months ago my check engine light came on. had my friend put his scanner on and check it, the car came back with p1646 i ran the car until it finally stopped running and had to be towed home, i finally ordered the o2 sensor and changed it out today, tried starting the vehicle after changing the o2 sensor( bank 1 upstream sensor) it started but quickly died out, i disconnected the battery for 30 minutes and tried to restart the car, the car started up fluttered a bit then went back to idling like nothing was wrong I took it around the neighborhood and it drove fine, when i got home i turned the vehicle off and tried to start it back up, it would start but quickly starts to idle roughly and then dies out. i dont know what else to check because the scanner is not reading anything but the p1000 DTC
Old 04-23-2014, 02:24 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
Wrong sensor? Fitted badly? Failing battery?
Old 04-23-2014, 03:47 AM
bighoks's Avatar
the sensor was the exact same one that came out of vehicle, now after cranking the car so many times the battery is starting to die, the vehicle ran for about ten minutes after changing the sensor but now it just cranks up sputters and dies out, seems like its not getting gas
Old 04-23-2014, 04:45 AM
JagV8's Avatar
Did car sit for a while? Seems to kill fuel pumps. Also, maybe change fuel filter. Either way, check fuel pressure.
bighoks (04-23-2014)
Old 04-23-2014, 04:47 AM
bighoks's Avatar
car sat for about 3 weeks since it got towed home, gonna change out the fuel filter tomorrow, and check the fuel pressure also. what is the fuel pressure supposed to be at? also forgot to mention i got a P0191 code when i ran my scanner on the car
Old 04-23-2014, 05:18 AM
police666's Avatar
see attached pdf
File Type: pdf
Old 04-23-2014, 06:27 AM
JagV8's Avatar
That's a fuel pressure code so ....
Codes PDF is in stickies and in JTIS, both free download
Old 04-23-2014, 07:30 PM
bighoks's Avatar
changed fuel filter then started it, got 40psi but the car was running rough, then i turned car off disconnected the fuel pressure gauge and now the car doesnt want to start, i reconnected the fuel pressure gauge and now im not getting any fuel pressure, could it be the fuel pump? or the fuel pressure regulator?
Old 04-24-2014, 01:32 AM
JagV8's Avatar
40 is low. None suggests the pump.
Old 04-24-2014, 01:42 AM
bighoks's Avatar
Would the maf sensor have anything to do with it not running after I try starting the vehicle
Old 04-24-2014, 05:48 AM
police666's Avatar
see post number 6
Old 06-13-2014, 05:10 AM
bighoks's Avatar
Changed the fuel pump today and I'm getting a rough idle and car starts intermittently, it will start then die out then after a couple tries the motor will sputter then idle at 1000rpms but with a bad idle. I'm at a stand still and can't figure out what is wrong with the car.
Old 06-13-2014, 07:30 AM
Received 6,241 Likes on 5,442 Posts
Did you follow the troubleshooting guide in post #6?
stanjag
08-30-2015 10:35 AM
nelsonht
08-30-2015 06:01 AM
swarm27
08-29-2015 07:37 AM
NorJag
E type ( XK-E )
08-28-2015 07:31 AM
Terrance Williams
08-26-2015 11:50 AM
Quick Reply: idle problems 2003 jaguar S type 3.0l
