idle problems 2003 jaguar S type 3.0l
about 6 months ago my check engine light came on. had my friend put his scanner on and check it, the car came back with p1646 i ran the car until it finally stopped running and had to be towed home, i finally ordered the o2 sensor and changed it out today, tried starting the vehicle after changing the o2 sensor( bank 1 upstream sensor) it started but quickly died out, i disconnected the battery for 30 minutes and tried to restart the car, the car started up fluttered a bit then went back to idling like nothing was wrong I took it around the neighborhood and it drove fine, when i got home i turned the vehicle off and tried to start it back up, it would start but quickly starts to idle roughly and then dies out. i dont know what else to check because the scanner is not reading anything but the p1000 DTC
bighoks (04-23-2014)
car sat for about 3 weeks since it got towed home, gonna change out the fuel filter tomorrow, and check the fuel pressure also. what is the fuel pressure supposed to be at? also forgot to mention i got a P0191 code when i ran my scanner on the car
changed fuel filter then started it, got 40psi but the car was running rough, then i turned car off disconnected the fuel pressure gauge and now the car doesnt want to start, i reconnected the fuel pressure gauge and now im not getting any fuel pressure, could it be the fuel pump? or the fuel pressure regulator?
Received 6,241 Likes
stanjag
08-30-2015 10:35 AM
swarm27
08-29-2015 07:37 AM
Terrance Williams
08-26-2015 11:50 AM
