Mass air flow
Hi David and welcome to the forum.
Please introduce yourself here:
https://www.jaguarforums.com/forum/n...-intro-must-5/
David Corfield (10-03-2018)
I am not sure about the diesel version but on petrol brothers the MAF Sensor is the easiest thing swap out. Should be located right after the air box on the intake tube.
Just FYI, the petrol version S Types like the Densi OEM sensors. Do not go cheap only leads to problems.
Good luck and let us you know how you make out.
Received 2,579 Likes
You can pay a garage £50 to replace the MAP sensor, or do it yourself.
Refer to the Workshop Manual for the location and procedure. If you don't have the Workshop Manual, you can purchase one here:
https://www.ebay.co.uk/itm/Jaguar-S-...wAAOSwjuFbmWyk
Thank you.
Good luck and let us you know how you make out.[/QUOTE]
i found this out the hard way after 3 ebay 14 dollar ones..the entire engine management system is denso..even a bosch lambda sensor makes trouble i found out.
Hmm....I have several readouts, supplied by the AA:
PO102-mass or volume air flow circuit:error message: Malfunction. Error sporadic. Status:UO164-CAN communication with air conditioner control unit. Error message:Malfu Malfun. Historical fault. Status:P244B-Diesel particulate filter. Error message: Malfunction.
David Corfield (10-04-2018)
Replaced MAF sensor, fault still remains. Will drive fine for 3-4 miles, then yellow and red light, restricted performance. Garage attempted to do a regeneration, however the car kept going into limp mode. Plugged another diagnostic reader in, it read there was 3.2g of soot, doesn't sound a lot, also the read out said that there hadn't been any failed regen attempts. The pressure hoses for the DPF to the regulator had a split, repaired that, problem still there.
i am at a loss as what to do next.
Greg561
05-14-2009 02:27 PM
Xistnnn
02-27-2009 12:58 PM
