Operating Coolant Temperature
Old 10-29-2020, 10:05 PM
omgimali's Avatar
Default Operating Coolant Temperature
What should be the operating coolant temperature? I知 running 201-203 around the city. and 198 in the highway. idling i知 doing 203-206 after a good drive. is this normal? what痴 the best temperature? After a good beating, the car will hit 208, and the fan will come on time to time
Old 10-29-2020, 10:08 PM
Received 2,577 Likes on 1,783 Posts
It would be helpful to know the vehicle details.
Old 10-29-2020, 11:13 PM
omgimali's Avatar
2005 Jaguar S Type R Supercharged 4.2L V8
Old 10-30-2020, 07:28 AM
Received 1,420 Likes on 1,063 Posts
Your good with those stated temps...
The following 2 users liked this post by abonano:
kr98664 (10-30-2020), omgimali (10-30-2020)
Old 10-30-2020, 07:32 AM
You should notice that the fan will run constantly on "low" when fully warmed up. A good test to ensure your temps are good is when you shut the car down.
If the fan goes off your good. Usual first tell tale sign of engine running hot is hearing the fan run after engine shut down.
I have an 04 XJR and I just swapped off a few coolant hoses and I've been monitoring temps and im running pretty much right where you are and I have zero issues!
My highway temp is around 194 - 196.
Old 10-30-2020, 07:44 AM
omgimali's Avatar
Huge thanks, i know how these motors get if they get too hot
Old 10-30-2020, 10:34 PM
So the temp gauge on the dash is of no use.
It will stay on dead center from about 170 degrees to about 230 degrees.
If the needle moves up past dead center you have issues, but the fan running after engine shut down is a pre cursor to a cooling issue or an impending issue...
When the engine is "hot" the PCM will run the fan on high after shut down to cool the coolant down...
Old 10-30-2020, 10:44 PM
If the radiator fan is running when the engine is shut off, the thermostat is most likely the cause.
Old 10-30-2020, 10:46 PM
The instrument cluster gauge does not change between 96 C and 128 C, which is problematic as the chance of warping the block and or heads is very likely.
omgimali (10-31-2020)
Jomiltom
02-15-2020 05:10 PM
kreyszig
07-02-2014 06:43 AM
wekrico
04-03-2013 02:26 PM
motogirl_94518
07-15-2012 12:23 AM
ATerry
04-16-2009 12:54 PM
Quick Reply: Operating Coolant Temperature
