Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > S-Type / S type R Supercharged V8
Sign in using an external account
Register Forgot Password?
Search
S-Type / S type R Supercharged V8 1999 - 2008
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Newbie w/ a key lock problem
LinkBack Thread Tools Search this Thread
Old 10-22-2011, 08:53 AM
andy303's Avatar
Default Newbie w/ a key lock problem
We just acquired a very nice 2003 3.0L S-type, 73K miles. Everything works great except the remote keyless entry system. We knew this when buying and the PO even mentioned it in his ad. The PO had replaced the battery in the remote to no effect. Before buying I read a number of threads on the topic in this forum and others, and it didn't seem to be a big enough issue not to buy a v. nice car at a reasonable price. Nevertheless, I would like to get it fixed.
One clue may be that when the key is removed from the ignition a chime continues to sound as long as the door is open. Might this mean that the car thinks that the key is still in the ignition, and won't therefore enable the remote? The central locking works fine using the key in the door lock.
Thanks!
Andy
Old 10-22-2011, 09:17 AM
motorcarman's Avatar
Photobucket
The chime is usually a 'key still in ignition' or 'lights still on'
The fob will not lock if the 'switch flap' is stuck in the 'key in' position.
This was an issue with the X-Type but I have seen it in the S-Type as well.
You could also have the 'static damaged' keyfob transmitter.
bob gauff
File Type: pdf XT501-22 Unable to Lock the Vehicle Using Key Fob.pdf (23.7 KB, 50 views)
__________________
Owning and repairing British and German cars since the early 70's
2001 XJ8 Mistral
1999 XJ8L Topaz
1985 XJ6 Belgian Import (Gray Market project car)
1985 XJ6 (Parts Car)
1983 XJ6 (Parts Car)
1992 Sovereign (sold)
2001 S-Type 4.0 (sold)
1997 XJ6L Black (sold)
1997 XJ6L White (sold)
1972 XJ6 (sold)
1966 'E'Type (first Jaguar) (sold)
Old 10-22-2011, 09:23 AM
Thanks for the TSB Bob!! I have not seen this problem before. Any idea what a new lock cylinder costs?
Also check it with the other fob if you have it. The S Type comes from the factory with two regular key fobs which are black and a valet key fob which is green. Very common to get a car with only one key fob. They are pretty expensive to replace and the dealer needs to program them for proper operation.
Old 10-22-2011, 12:11 PM
eds123's Avatar
I had this same problem but mine was caused by the 2 bolts on the tranny shifter cable plate being loose. The car was going into park but not fully making the key fob not work and door chime to ding because it thought the car was not in park. Tighten the bolts down and it's been perfect sense. This would be the cheapest route to check first.
Old 10-22-2011, 01:01 PM
andy303's Avatar
Thanks for the tips guys!
I'll check the loose cable theory. Is it easy to access?
__________________
Andy Blackley
67 Jaguar Mk 2, 2003 S-type 3.0
http://www.saloondata.com/cars/detail/?car=P181438BW
Old 10-22-2011, 02:25 PM
Default linkage bolts
Take a look at the S Type oil change video on you tube. It will show you where the bolts are and give a better general understanding of your new vehicle.
__________________
arty914
07 S Type 3.0
75 Porsche 914 2.0
Is it valid to critisize near perfection?
Old 10-22-2011, 04:13 PM
andy303's Avatar
arty: Yes, I saw that in the FAQ. Is it necessary to remove the belly pan first to get at those bolts?
__________________
Andy Blackley
Old 10-23-2011, 06:38 AM
joycesjag's Avatar
No the belly pan does not have to be removed.
__________________
Happy Wrenching
Rick
2005, S Type 3.0
77,362 miles
Old 10-23-2011, 03:35 PM
andy303's Avatar
Well, I checked the two bolts. One snugged up a tad, the other was tight. No difference there. The chime still rings with the door open.
I also checked the park function on a slight incline. The car rolls in neutral, but holds in park, so I am thinking the problem is elsewhere. The looseness in the ignition lock worries me. Between 0 and I there is no resistance, and from I to II only slight, when you turn the key to the right.
__________________
Andy Blackley
Old 10-23-2011, 05:08 PM
andy303's Avatar
One other clue, maybe. The electric parking braking will activate, but not release, using the button on the console. It releases when put in reverse or D.
__________________
Andy Blackley
Old 10-23-2011, 05:58 PM
Photobucket
IS THE SWITCH FLAP IN THE LOCK CYLINDER STUCK???????????????????????????????????
bob gauff
__________________
2001 XJ8 Mistral
1999 XJ8L Topaz
1972 XJ6 (sold)
Old 10-23-2011, 06:45 PM
andy303's Avatar
Bob:
Not sure about a stuck switch flap. I did lube it, and I can see something moving out of the way when I insert the key or small screw driver. When stuck, what would it look like? An open large open hole? What I am seeing is a metallic flap that pivots downwards freely when pushed. However this flap does not cover the entire opening when it pivots back into a closed position. There is a small gap, about 1/8 inch wide or less at roughly a 1 to 3 o'clock position on the key opening.
__________________
Andy Blackley
Old 10-24-2011, 01:54 AM
It's a critical part of the very systems which you have identified as faulty, so it looks like #1 suspect. You could probably acquire a working one cheaply (wrecker/ebay) and either compare against that (if you wish to, mainly out of curiosity) or just swap it. It's the electrical part that is at issue, so an alternative is to figure out all the things it should do in each switch position and check electrically that it does them all, reliably. (I'd swap for another.)
__________________
STR 2004. Acronyms: http://www.jaguarforums.com/forum/s-...-jaguar-78910/
If you would like the most accurate assistance, it is very helpful to place your vehicle information into your signature line, just look in your member control panel to set it up. Info like year, model, engine size, and other details like mileage can only aid in receiving more replies with the correct information. (thanks, h20boy!)
Old 10-24-2011, 05:37 AM
andy303's Avatar
If I swap another switch will I need new keys too?
I have been looking on eBay and it seems that MY2002.5 is a break point for the the assembly. Is this correct?
__________________
Andy Blackley
Old 10-24-2011, 06:26 AM
I don't know for sure but I don't think so. Chances are you have a mechanical issue that's causing an electrical one due to years of use so you can probably fix / swap. The FAQs have a PDF with specs of VIN breaks - there are several.
__________________
Old 10-24-2011, 12:46 PM
andy303's Avatar
Thanks.
In the S-type parts guide in the FAQ the part number for the ignition housing assembly (XR8015757) and the ignition lock (XR8013528) are the same for all years, but then under 2003-2005, in addition to XR8015757 it has two additional part numbers for the ignition housing assembly listed for manual and automatic transmission. Which to use?
It also appears that the ignition lock, the mechanical part, is a separate assembly and is not included with the ignition housing assembly. I assume that the original lock could be used with a new housing assembly. If I have to replace the lock, then I suppose new keys are required. Can one replace just the actual key without having to also replace the fob?
__________________
Andy Blackley
Tags
2003, brakes, central, door, fob, ignition, jag, jaguar, key, lock, malfunction, rear, release, stuck, stype, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
