Parkbrake Fault will not reset.
Before im advised to search how to reset the parkbreak I know what to do and have tried many times.
Its 3 months away from MOT time and my park break fault is still perminently on. I have had new breaks fitted even though my garage said they were only half worn but was worth a try. After fitting them they did the test they would do for an MOT and said the breaks are 100%. I have tried resetting the normal way and i have tried releasing the parkbreak before disconnecting the battery. I have tried resetting with a newly recharged battery and with the car in high revs. I bought a second hand parkbreak module and this did exactly the same. I did notice a very small amount of blue corrosion on 1 or 2 of the wires going into the plug for the module though but having cleaned it off still have the same problem. Any thoughts greatly welcome as I dont want to spend £100s when the breaks work perfectly.
Thanks.
Thanks.
dmatthewman
09-30-2015 10:10 AM
