Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > S-Type / S type R Supercharged V8
Sign in using an external account
Register Forgot Password?
Search
S-Type / S type R Supercharged V8 1999 - 2008
Sponsored by Simple Tire
Click Here
LinkBack Thread Tools Search this Thread
Old 01-01-2010, 12:23 PM
Jaguarjc
Guest
Posts: n/a
Exclamation Phone system work with cell phone?
I just purchased a 2003 s type jaguar, it has a built in phone system with button the on the dash and steering wheel. What is required or what do I need to make the system work with my cell phone?
Old 01-01-2010, 12:55 PM
MDJag's Avatar
if your cell phone has bluetooth capabilities you have to link the two. your owners manual has directions on how to. if you dont have one or need assistance let me know.
__________________
2011 XJ - Cashmere with Oyster/Pearl interior, Aleutian rims, Illuminated Tread Plates
-Every day is a gift from God-
Old 01-01-2010, 01:02 PM
It almost surely does NOT have bluetooth. It's a cell phone, so put a SIM card in if it hasn't one. Swap in your other phone's card if you wish.
Jaguarjc
Guest
Posts: n/a
Quote:
Yeah my phone does have bluetooth. It doesn't matter what type of phone right?
Old 01-01-2010, 01:12 PM
MDJag's Avatar
turn ignition swith to on and press the telephone button on the audio panel. enter ##3#*# using the panel keyboard. press the on-screen call icon or call button on the screen. prepare your phone to connect using blutooth through settings on your phone. select search for devices after search select jaguar and enter code 1313 press ok to confirm. hope this helps
__________________
Old 01-01-2010, 01:26 PM
Er.... your jag phone is what I meant (almost certainly) NOT having bluetooth.
Old 01-01-2010, 04:07 PM
This has been a bit confusing.
The pre-2005 models used a Jaguar phone and wiring that was not bluetooth compatible.
The 2005 and on models used a bluetooth module that was not compatible with the older model.
You have a choice. You can use the older Jaguar phone, if you have one or can find one, or you can refit your car for bluetooth. It is said that this is not terribly difficult to do.
Look at Msg #7 in this thread for a pdf that explains how to make the conversion.
s type audio/bluetooth
__________________
Eric
2005 S-Type 3.0
Montgomery, AL
Old 01-02-2010, 08:26 AM
JOsworth's Avatar
The first question that needs to be asked.... Does your car actually have the integrated phone. A GREAT many people think that just because there is a phone button on the stereo that it has the phone while the cold reality is majority of them do not have a phone installed. All the radios have the phone button since it is an accessory. The easy check is look up at the overhead console. Between the sunvisor and console there will be a separate microphone installed on the headliner.
__________________
Jeff
07 Chrysler 300C (Yea, It's gotta Hemi)
06 Mercedes R350 (the mommy bus)
85 Dodge 600es Turbo Conv.; all original w/ 41k
Gone but not forgotten - 2005 S Type 3.0
"Just because you read the manual doesn't mean you can drive the car."
www.terminalsandconnectors.com
Old 01-02-2010, 09:15 AM
Do the pre-2005, Jaguar integrated phone, cars have the headliner microphone?
I had always thought that this type installation used a handset that was stored in the console. Curious...
Eric
__________________
Eric
2005 S-Type 3.0
Montgomery, AL
Old 01-02-2010, 09:16 AM
Er, mine has the jag phone but I don't think the mic's there! Must look up and make sure....
(And mine's NOT bluetooth; it's a 2004 STR with satnav, premium Alpine etc.)
Yes, the handset is in the console but you can leave it there and use the system hands free so there's a mic SOMEWHERE lol.
Old 01-02-2010, 02:00 PM
Well ... if you find the microphone, let us know. <g> Do you have to speak very slowly and carefully into the Jaguar head emblem in the steering wheel?
Eric
__________________
Eric
2005 S-Type 3.0
Montgomery, AL
Old 01-02-2010, 02:41 PM
Just don't let your wife hear you doing it without letting her know..
Old 01-02-2010, 05:16 PM
The early cars used a mic in the overhead console. Many complaints about poor sound quality. Then the external mic came out and it plugs into the overhead console. Here is a picture of the external mic if you have one.
Phone system work with cell phone?-bluetooth-microphone-jpg
Old 01-03-2010, 06:56 AM
Definitely no separate mic visible in the headliner, but there's a grille in the roof console so that is probably the mic.
Old 06-24-2010, 10:59 AM
willisgrn83
Guest
Posts: n/a
This is an interesting discussion. thank you for sharing
Old 11-22-2010, 09:19 AM
Default 2005 bluetooth???
I have a 2005 STR and it doesn't have bluetooth that I'm aware of. And it has mic's all over the inside cabin, so I assume they were meant for voice recongition and the phone???? I guess I can research and look at the manual but how does this thing work? I have an iPhone 4 that suck in the car and was wondering if I can use the car phone built-in (if it is, how can I check)???? I don't have Navigation.
Thanx.
Old 11-22-2010, 09:41 AM
JOsworth's Avatar
Quote:
Thanx.
First things First.. All those little buttons are sensors for other things, like climate control. Not microphones....
Second of all... All Jaguar head units (stereos) in 2005 have built in CONTROLS for the phone...Nothing more. The phone had to be added as an extra module. They just built one stereo since that would lessen the complication of adding the phone later. (Also a convenient way to up sell customers on the phone as well when they ask "What does that phone button do?"
The easiest way to check for the phone is to look for the microphone pictured below in post #13 from Tbird6. Also, if you unscrew and pull the console box, there should be a phone module mounted there. (That is where it goes when it is added). If no module, then no phone. If you wish to add it, it is pretty easy but real expensive.. I have yet to find one on the cheap... Less $$$ to pull the head unit and replace it with one that has built in bluetooth.
__________________
Jeff
Old 11-22-2010, 09:34 PM
On my 2001 (with no indication of an installed phone) the phone button on the dash and the steering wheel mute the radio so you can take a phone call.
Old 11-23-2010, 09:09 AM
Major redesign in 2002/3 so buttons etc changed lots.
+1 on Jeff's reply.
__________________
STR 2004. Acronyms: http://www.jaguarforums.com/forum/s-...-jaguar-78910/
If you would like the most accurate assistance, it is very helpful to place your vehicle information into your signature line, just look in your member control panel to set it up. Info like year, model, engine size, and other details like mileage can only aid in receiving more replies with the correct information. (thanks, h20boy!)
Tags
05, 2003, 2004, bluetooth, button, card, jag, jaguar, module, phone, sim, stype, type, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
