Problem no fuel pump working help please s type R
Hi just need help ive just bought a Jaguar S Type R 2002 the car was running fine apart from Engine Light on Dashboard just parked the car then tried to start the car the next day and no fuel pumps are working??
Do i need to change Fuel Pumps or is their anything i should check or change??any help will be Fantastic
Anointme123 (03-03-2012)
Try changing the fuel filter first - when doing so if you see any silt or dark fuel (blackish brown) or any material coming out of the fuel filter - odds are that your fuel pump burnt out. This is a common issue, especially when sitting for a while. You can also check the inertia switch under the panel - drivers side - black unit with red button - ensure that is pushed in. Good Luck
Anointme123 (03-04-2012)
Thanks for all your help i will change petrol filter and check colour etc, The car started today without changing anything but thenn stopped after 10 minutes the Fuel Gage is on a quarter so maybe the fuel pump because i here that their 2 pumps intank, I also have seen that lots of people have changed the fuel pump wires.
Thanks again for your replys
BrentGardner
26
04-17-2024 05:19 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
msdg137
09-16-2015 06:24 AM
stanjag
08-30-2015 10:35 AM
