Remove headlight on 2004 S-Type
Hi,
Does anyone know how to remove a headlight WITHOUT removing the bumper from a 2004 S-Type? Tried to retrieve a loose bulb inside without any luck (or any other tips on this).
Thought that I saw somewhere that somebody had accomplished this. Any help much appreciated.
Thanks,
Boog
3.0 S-Type 2004
Thanks,
Boog
3.0 S-Type 2004
As far as I know the only way is to remove the bumper cause you have to access some bolts that you cant get too with the bumper on. Here is the write-up for removing the bumper.
https://www.jaguarforums.com/forum/s...e+front+bumper
If the bulb still has some metal on it, not sure if you are talking about a whole bulb or broken fragments you might be able to get a magnetic wand and get it through the headlight bulb opening. I have one of these in my tool box and it helps alot when dropping stuff.
http://www.harborfreight.com/15-lb-c...ool-95933.html
Boog (05-21-2011)
Three weeks ago my turn signal bulb fell into the assembly and i had to take the bumper off. I had to open up the head light this also gave me a chance to fix droopong headlights that failed and were not able to be fixed by brutals method. Removal was simple besides the two bolts in the inner wheel wells that are a pain in the ***.
Jumpin' Jag Flash (06-04-2015)
Got the same problem my old S Type Sport failed it's first MOT test on this today, so I have another that I bought for the plate PG03 JAG (Cool Eh) and for spares, so instead of taking of the brand new headlamp assembly off that car I will give this a go first, didn't fancy having to drop the front bumper so thank you to you all for the instructions and video - awesome stuff!
John
John
