Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > S-Type / S type R Supercharged V8
Sign in using an external account
Register Forgot Password?
Search
S-Type / S type R Supercharged V8 1999 - 2008
Sponsored by Simple Tire
Click Here
LinkBack Thread Tools Search this Thread
Old 09-14-2009, 10:10 PM
Default S-Type Fob and Key
I asked a question a couple of days ago and got several answers. Thanks.
I located two used fobs for $20.00 each. One new one costs over $200.00.
A new key will cost $64.00
And about $135.00 to program the fob.
Is there anyway to program it yourself or is there a cheaper way? The cost sounds exhorbitant, and the dealer seems to be taking advantage of customer.
Can an ordinary locksmith program the fob?
Thanks for all your help!
Steerforth!~
Old 09-15-2009, 12:41 AM
Photobucket
Short answer which I think I posted in the original thread, NO.
__________________
2003 S Type V6
2005 XK8
Old 09-15-2009, 02:50 PM
SI, Seņor!
Yo vivo en Mexico
Bubba Free Toe
(Free Toe Bandido)
Old 09-15-2009, 06:25 PM
Steerforth,
We probably need to put this on a FAQ for new buyers BEFORE they buy the car so buyers know to negotiate adding a key(s) and fobs and have them build the cost in to the deal if they buy from dealers or know to take care of it when they buy private party.
It is actually a great security move as the dealer usually verifies ownership. The keys are all re-programmed as a group. The result is any old keys the previous owner did not give you won't work after programming.
Also, if you get a valet key and use it as intended, if the valet has tried to re-program a key set to come after your jag later that night and look in glove box for your address,a couple of things make it awckward. First, the valet key does not allow access to the glove box or trunk so a little more awckward to get address. Second, by giving them the valet key. When you get back in the car start it up with your regular key, if they do get a chance to re-program the car and key, your regular key won't work and you know something is up right then.
It is kind of like buying a house, you generaly want to change the locks. With programmable keys, you actually are a lot more cost effective than the good old days when you had to change lock cylinders.
I also got three different prices on programming from same dealer. Reminded them of the one of all keys and fobs for $100 and they honored it if there are a few dealers around, it might save a few bucks to call.
Regards,
Steven (1avguy)
Old 09-15-2009, 07:43 PM
RickMG's Avatar
Steerforth!~
Okay, are you talking about programming the key fob or the key? You can easily program the fob that you just bought for $20 by following the instructions here:
http://jaguarforums.com/forum/showthread.php?t=2056
If you have more than one fob, press them both within a few seconds of each other so they will be programmed the same. This is for an X-type, but I believe the key fobs are the same.
Now, if you find a way to get a key for $64 that will work, please, let me know.
Old 09-16-2009, 12:39 AM
Photobucket
The S type is different, it needs a trip to the dealer, the X can be done as detailed by Jim.
__________________
2003 S Type V6
2005 XK8
Old 09-16-2009, 11:34 AM
RickMG's Avatar
Quote:
Man, that's a bite.
Old 09-17-2009, 10:20 PM
My head is spinning!
I have to take the fobs to the dealer to program? I have one working fob and key already. I want a spare set.
The Jag dealer in San Diego quoted me $64.00 for the key, but to program it is over $100.00. Starting with the 2000 S-Type, there is a programmable chip in the key, right?
A new fob costs over $200.00, but I managed to find a couple of used ones.
S.
Old 09-20-2009, 10:21 AM
Steerforth,
I was hoping someone with direct s-type experience would chime in as there are a few diffrences in key programming issues between models and mine is a 2003 XK8 coupe.
I believe all of this era/vintage have a transponder within the key that has to be programmed. On mine, all keys have to be programmed at the same time as the transponders all as well as the car are reset to new code, defeating use of any old keys that were not re-programmed. Bring all keys and fobs with you for re-programming and test all of them befroe you leave.
Make sure the fobs are from/for your type of Jag. They are not all the same, hence why some can be programmed by end user and some require dealer action.
With Best Regards,
Steven (1avguy)
Old 09-21-2009, 03:19 PM
d33 d33 is offline
I took my fob to the dealer, and they reprogrammed them (as stated, as a group) and it was covered under warranty.
Old 09-22-2009, 11:12 AM
Photobucket
you need a scan tool (ids/wds) to program the key and remote
__________________
Jaguar master Tech
Old 09-22-2009, 11:51 AM
Steerforth-
If it was a simple matter, it wouldn't be much of a security system.
Eric
__________________
Eric
2005 S-Type 3.0
Montgomery, AL
Old 05-26-2010, 01:22 PM
Hi,
is it the same thing, when I just changed the battery of the remote? Cause it doesn't work anymore..
thx, greetz
Paul
Old 05-27-2010, 12:51 PM
Quote:
Originally Posted by Caesar View Post
Hi,
thx, greetz
Paul
Seems to me I may have read somewhere that it must be reprogrammed when you change the battery, but I'm sure somebody with more knowledge will reply.
On another note, a few weeks ago I found the lost key and fob that cost me an arm and a leg to replace. Bittersweet, but nice to know it wasn't stolen.
Steerforth!~
Old 05-27-2010, 03:00 PM
JOsworth's Avatar
I have heard that it can happen (loosing the programming when changing the battery) but it is not supposed to. If the key no longer works, the dealer is the only ones that can reprogram it.
__________________
Jeff
07 Chrysler 300C (Yea, It's gotta Hemi)
06 Mercedes R350 (the mommy bus)
85 Dodge 600es Turbo Conv.; all original w/ 41k
Gone but not forgotten - 2005 S Type 3.0
"Just because you read the manual doesn't mean you can drive the car."
www.terminalsandconnectors.com
Old 05-27-2010, 03:31 PM
androulakis's Avatar
Send a message via AIM to androulakis
I had a terrible time with keys losing their programming for no apparent reason. All the keys would start the car and turn the ignition, but the keyless entry would die. I finally went with an aftermarket keyless entry unit which installed relatively easily in the driver's door, and haven't had a single problem since.
George
__________________
George Androulakis
J&M Automotive - Hamilton, NJ
Sales - Service - Performance - Accessories
Personal Collection:
1999 Arden Jaguar Xk8 20" HRE 540's
07 Range Rover HSE - 22" Redbourne Nottinghams
10 Mercedes C300 4Matic
03 BMW 330ci Cabriolet
00 Mercedes e320 4matic (daily beater)
03 GMC Sierra Ext Cab - 4" Lift / 33's on AE 027's
96 Chevy Impala SS
95 Pontiac Trans Am
E-mail me - george@rmexoticautos.com
Old 09-13-2010, 07:57 AM
carelm's Avatar
Over the weekend I got the "flip out" section only for a spare key. It cost me about $70 but the dealer had to program it at no charge. Now I'll have to scrounge up the remote piece. E-Bay had some for about $55 so I may go that route. Apparently the dealers don't sell just a key anymore.
Mike
__________________
2005 S-Type Zircon 3.0 V6
2001 Audi A6 Avant Ming Blue Pearl 2.8 V6
Rotating Jaguar Pictures
Old 09-13-2010, 08:00 AM
Quote:
Mike
Carlem,
I've got 4 or 5 used complete keys from when I was trying to get my keyless entry working (before I went aftermarket). E-mail me, geoandroulakis@gmail.com I'll let them go cheap.
George
__________________
George Androulakis
96 Chevy Impala SS
95 Pontiac Trans Am
Old 04-18-2012, 11:28 AM
Default Found on http://www.fixya.com/cars/t1445964-program_s_type_jaguar_key_fob_year_2000
Have you tried this approach?
Seperate key fobs only can be programmed in the following way.
Turn ignition on/off 8 x times (allow all functions to stabilise) after the 9th on - press a button on both remote fobs. then turn ign. off. use good remote to lock and then try new remote to unlock/lock. sometimes it works first time - sometimes you have to repeat actions. good luck.
__________________
2x 2000 Jaguar S Type 3.0 V6
Old 04-18-2012, 12:12 PM
No, they cant. Not on an S-Type.
There is no back door, no user programming sequence. You NEED to take the car to a jag dealer or an independent who has IDS.
Take care,
George
__________________
George Androulakis
96 Chevy Impala SS
95 Pontiac Trans Am
Tags
2000, 2003, fob, jaguar, key, program, programme, programmed, programming, reprogram, reprogramming, stype, type, valet, xj8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
