S-type v6 2000 codes P0303 and P0353
Old 10-17-2009, 09:33 AM
dijmand's Avatar
Default S-type v6 2000 codes P0303 and P0353
Hi guys I need your help !
I just recently changed all 6 ignition coils and things ran great for about a week. Now I am getting rough idling and these codes...
P0303 and P0353
What should I check?
Standing in front of the hood, which one is cylinder 3?
Old 10-17-2009, 01:29 PM
JOsworth's Avatar
Originally Posted by danielsatur
Did you read the 3-pages on Thread '' Misfiring Issues'' ?
See also
http://www.automotiveforums.com/vbul...d.php?t=882939
Yea, like you read them...... Stand aside and let others that actually know what they are talking about help this user out.
Glad to see you know how to copy and paste links in automotive forums as well!
Old 10-17-2009, 08:10 PM
carelm's Avatar
Per JTIS, this is the cylinder layout:
The right-hand cylinders are numbered 5,3,1 and the left-hand cylinders are numbered 6,4,2 when viewed from the rear of the engine
Based on this the #3 cylinder would be the middle right one.
Here is some info from JTIS that hopefully will help:
P0303 EMS
OBD II
Misfire detected – cylinder 3
*Refer to Misfire Note, page 6
Misfire monitor drive cycle –
page 6
1 or 2* N None — Refer to P0300 Possible
P0300 EMS
OBD II
Random misfire detected
page 6
1 or 2* N None — ECM to ignition coil primary circuit fault
(Cylinder misfire detected DTC also
flagged)
Fuel injector circuit fault(s)
(Injector DTCs also flagged)
Ignition coil failure
Spark plug failure / fouled / incorrect gap
Cylinder compression low
Fuel delivery pressure (low / high)
Fuel injector(s) restricted / leaking
Fuel injector(s) continuously open
Fuel contamination
Worn camshaft / broken valve spring(s)
P0353 EMS
OBD II
Ignition module primary circuit
malfunction – cylinder 3
Start engine
Battery voltage > 12 volts
Idle for 2 minutes
2 A ECM Default:
– Bank 1 closed loop fuel
metering inhibited
– Bank 1 sub feedback control
inhibited
– Bank 1 adaptive fuel metering
inhibited
– Maximum engine speed
reduced
– Fuel injection cut off
(cylinder 3)
PI1
-088
ECM to ignition module primary circuit:
open circuit, short circuit to ground,
high resistance
Ignition module ground circuit:
open circuit, high resistance
Ignition module / coil failure
JTIS diagnosis page 6 info
MISFIRE MONITOR DRIVE CYCLE
1 Record flagged DTC (s) and accompanying WDS DTC Monitor freeze frame(s) data.
2 Fuel level > 25%.
3 Start the engine at a coolant temperature lower than the recorded freeze frame value (from Step 1).
4 Drive the vehicle to the recorded freeze frame conditions for 4 minutes. If CHECK ENGINE MIL flashes, lower the engine speed until the flashing stops.
Note regarding misfire monitor DTCs:
If, on the first trip, the misfire is severe enough to cause excess exhaust emission, the individual cylinder DTC plus DTC P1316 will be logged. The CHECK ENGINE MIL
will not be activated. If the fault reoccurs on the second trip, the individual cylinder DTC plus DTC P1316 will be flagged, and the CHECK ENGINE MIL will be activated.
If, on the first trip, the misfire is severe enough to cause catalyst damage (more severe than excess exhaust emission), the CHECK ENGINE MIL will flash while the
fault is present and the individual cylinder DTC plus DTC P1313 (bank 1), DTC P1314 (bank 2) will be logged. When the fault is no longer present the MIL will be deactivated.
Hopefully this will help:
Mike
Old 10-17-2009, 10:48 PM
dijmand's Avatar
Hi guys I got my hands on the JTIS CD from ebay and as pointed out in a previous post, my cylinder numbering is: (year 2000 V6)
Transmission
3 6
2 5
1 4
FAN
Yes I have had problems with water leaking into the engine compartment and yes I did just get the car washed !
By the way, the valve cover gaskets and spark plug boss were also replaced, so unlikely that oil can be causing a short.
Since all six ignition coils have recently been replaced, I will check an easy one to reach like #4 and verify if the mechanic put any dielectric grease on it. (JTIS says that some dielectric grease should be applied) If there is none there then I am sure there will be none at cylinder #3
Perhaps the misfire code and the possible "primary circuit failure" code are the result of water leaks and poorly insulated connections.
Old 05-01-2010, 07:55 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
First: you're on the wrong forum, you do not have an S-Type
2nd: ignore anything by daniel.
I think your best bet is to find the right forum and ask again.
Old 05-11-2010, 12:31 AM
Kennedy's Avatar
i had the same problem once... The clip connection came off the coil. go to coil 3 and reconnect the wire clip. hopefully that fixes it.
Clare Jennings
10-04-2015 05:43 PM
Ragn0r
09-29-2015 10:38 AM
Quick Reply: S-type v6 2000 codes P0303 and P0353
