S type wheel stud
Old 02-22-2014, 01:37 PM
jaguarx00's Avatar
Default S type wheel stud
Checked at all auto shops for a wheel stud around my area and no one carries them. Dealer doesn't sell alone only the complete hub. Last option is Ebay never used it for sketchy reasons, but any other options? Thanks 2000 jaguar s type
Old 02-22-2014, 04:02 PM
androulakis's Avatar
Go to your ford dealer or auto parts store. Ask for a wheel stud for a same year Lincoln LS. Problem solved.
Dorman makes then in the aftermarket.
Make sure you have a deep well socket and an open ended lug nut. Preferably tap it in and then use an impact gun and the open ended lug nut and drive it in with that.
Take care,
George
Old 02-22-2014, 04:36 PM
jaguarx00's Avatar
Thank you!
Old 02-22-2014, 04:39 PM
OxfordTheCat's Avatar
I just ordered 40 wheel studs myself, so I can do an eventual full replacement:
I am in the middle of a brake job, and those damned two piece lug nuts got me.
Had to use a burr and a drill bit to get it off after it rounded.
My replacements were Dorman 610-484.
As you are in the United States, I'd say Rock Auto is probably your best bet.
Do a search under "Part Number" and you'll see them.
$1.21 a piece for less than 10, $1.13 if you're buying 10 or more.
Put this on both locations to make sure you see it.
tonimccloud
19
01-18-2020 01:56 PM
rvdz
12-07-2019 06:42 AM
h4wk
11-27-2015 05:10 PM
stanjag
08-30-2015 10:35 AM
Andrew McVey
16
08-27-2015 07:21 PM
Quick Reply: S type wheel stud
