Waterless Coolant
#181
Anyone who spends that much on some "magic coolant" is the ideal consumer for the expert marketing execs.
Please, by all means, buy train car tankers of this stuff.
As for me, I'm sticking with OEM since I buy 5% under wholesale, being a licensed dealer.
It's nice to have a dealer's license, especially in Alabama.
It's helping me that YOU can get 5% under wholesale so thanks for letting me know.
If I get a dealer's licence and move to Alabama that'll be me all set. Again, I'm so grateful you let me know.
I can't tell you how much you've helped with my concerns about the valley pipe and how it's affected by a pressurised cooling system.
Wait - I can. You've not helped at all. Again.
Please stop posting unless you can add something helpful.
#182
Received 2,255 Likes
You are correct that it seems to be a solution in search of a problem.
#183
#184
If being popular is important for you, I can assure you, you will be if you can bring some good technical knowledge/evidence, being it pro or con!
Sharpening up the discussion is only welcome, we can than give a great summary in a couple of months.
Is it really to much to ask to keep this thread on topic and more based on evidence/technical info?
#185
Assuming I measured correctly, I guess just like water that can evaporate at lower temperatures than the boiling point, Evans possibly also, or it somehow goes with the water vapor or so.
But this quick test does give an interesting possibility, in case the water content is to high, you could just boil it off.
I still don’t know if how it will work with the overflow tank, so if water vapor could get out as well, that is something I will have to check over a longer period.
#186
#187
You're unpopular when you say irrelevant things, disagree without evidence, put words in people's mouths they never used, beat a point to death especially when you never actually made a valid point and so on. That's what you've been doing. Destructive childish behaviour.
#188
That sounds like good news! Your microwave test was done at 130 C, not much above the temp that Evans might be expected to reach. So, if you run pressureless, any excess water will evaporate at that time, and then just top up with Evans.
#189
#191
OK, got it! Avos, you are a very bad lad for misleading us all by conducting your coolant tests at temperatures at which you must know engine seizures will occur. Go directly to jail....
#192
#193
OK, Mikey, let's put it another way...
The table below shows the boiling point in deg. C of coolant (ethylene glycol/water) at 0 psi and 15 psi, using different mixes:
% Glycol...... At 0 psi.... At 15 psi....
........0........... 100.......... 120
......33........... 104.......... 125
......50........... 108.......... 129
Now, here's a quote from you in this very thread...
So, cars are designed to operate at around 129 deg. C with no trouble throughout their service life. Yet you also state that at that temperature, engines are either about to seize or have already seized. There's a whiff of b/s in the air.
#194
I was just trying to see if you could boil of the water, and to speed it up I raised it to a higher temp. It would also have worked if I kept the temp lower, otherwise please enlighten me as to why water would not evaporate at lower temperatures then 130c.
But come to think of it, there could be hot spots in the head, and I would not be surprised if there you could reach these temperatures or higher. But that was not my check.
As said it was more anecdotal, but given the results it does give me the opportunity that if the coolant would go over the max 3% water, there is a way to get it out, without buying new again (even though that would not be an issue for me).
#195
It's not actually trying to run pressurised (which is probably why the coolant system has no pressure sensor) except that it has to with the OE coolant in order to run as hot as it aims.
#196
The boiling point of a coolant is completely unrelated to the design or actual operating temps of the cooling system.
#198
#199
