1999 S Type Reversing Sensor Problem
1999 S Type Rear Park assist only works in Drive
Hello All
I have had an issue with my Park Assist
When I bought car, working fine - After a couple of months;
Initially one of the sensors was not working (ear test) so I swapped the bad for good and purchased a new sensor
Put on new sensor and it still did not work - Double checked the sensor with a different position to find working fine
Checked the wiring for continuity and working fine
Opened box to find PCB damaged by water ingress
All this time the siren was sounding long and loud in reverse with only three sensors working
New box arrives, all same numbers - Plugged it in and all four sensors working
Problem is that they only work in every gear apart from reverse!!
I have no front sensors
Any ideas
Regards
Any ideas
Regards
Received 2,255 Likes
The numbers are the same and I recon the feed is from the rear lights (according to the WD) rather than CANBUS so I am reconing just to change the feed input
Of course nothing is easy - Pin 9 and 10 both show WR wires!!
Regards
XJR 308 (01-15-2017)
Unfortunately, I could find nothing definite - Some stuff works for some and not others, some on XP and some not
Looks like I will go with my earlier plan and if that fails, use the tow bar instead of the Park Assist............
Regards
Regards
That's not even this site let alone forum.
Still, makes two at most.
Whether the car(s) mentioned have CAN is impossible to say given the failure to post relevant details.
No wonder so little (or no) help is provided!!
Read the module - someone out there at a dealer or indy or wherever can do it, perhaps best with WDS. Or stare at the freely downloadable workshop manual and let us know what troubleshooting reveals?
What "relevant" details are you after? - Vehicle details are in my sig? - You said there was no CAN in my era of car?
Obviously posting an issue on a Forum is to hopefully get an anecdotal answer which alas looking rather slim in this case - Obviously getting codes read is the way to go, but with respect i could have worked that one out for myself
By posting on the Forum, I was hoping that someone could help me without the aggravation and expense of involving a third party
<sigh>
I think the comment regarding lack of info and absence of subsequent help was referring to the other forum and not your own particular case.
Hello All
Any ideas
Regards
Any ideas
Regards
Possibly your shift cable is stretched. (Meaning you may think your shifter is in P or N by the shift handle but the cable is out of alignment keeping the actual gear in R between P & N selections - and your parking aid system "active")
You do need to get your vehicle parking aid module read by Jaguar diagnostic software to get codes related to your issue.
No front sensors on 1999.25 - 2002MY's.
This system is rather simplistic...
