2003 S-Type - Likely Location Of Headlight Wire Break
No power to driver's side low beam headlight. Tested all fuses. All have power. Wire to this headlight which appears to be the problem is brown with white line. Using a jump wire from passenger side low beam headlight, driver's side headlight works, and I can turn lights on/off at stick on steering column The break in the wire for the driver's side low beam seems to be somewhere between where the driver's side low beam bulb plugs in back to and through the firewall into the dashboard.
Any experience with this very specific problem and likely location of problem would be appreciated.
smw
smw
Anthony8858
09-05-2016 10:48 AM
