location of Camshaft Position Sensor
Old 07-28-2012, 04:37 PM
bigalan's Avatar
Default location of Camshaft Position Sensor
Hi all,
I'm trying to find the location of the Camshaft Position Sensor for my Jaguar S-Type 3ltr v6 2001.
I have got the new one and have been searching a lot on this site and the web. Could someone point me in the right direction?
thanks bigalan
Last edited by GGG; 07-28-2012 at 05:45 PM. Reason: edit typo in thread title so it appears in searches
Old 07-28-2012, 05:46 PM
GGG is offline
Received 16,799 Likes on 12,168 Posts
Here's the sensor locations for your S-Type:
The CPS is item 3.
Attached Thumbnails location of Camshaft Position Sensor-s-type-electronic-engine-comtrols.jpg
bigalan (07-29-2012)
Old 07-28-2012, 08:34 PM
Received 9,005 Likes on 4,113 Posts
Homerun in one..............nice one Graham.
Sorted BigAl?
Old 07-29-2012, 05:14 AM
bigalan's Avatar
thanks ggg for the very fast reply.
this is whot i got when read the car with my pc (p0341 camshaft position sensor "A" circuit range performace) so orded 2x camshaft sensors hoping this will sort the problem was geting confussed with these and the crankshaft sensors will have look at car agen with the digram you have selplied and hope i can sort it thanks agen
Old 07-29-2012, 05:41 AM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
I knew I had some pics of the camshaft sensors (CMP)
Attached Thumbnails location of Camshaft Position Sensor-cam-position-sensor-pass.jpg   location of Camshaft Position Sensor-cam-position-sensor-drvr.jpg
Old 07-29-2012, 05:51 AM
GGG is offline
I often find a drawing of what the sensor looks like is as much, if not more help than where it's located.
The full description of possible causes for P0341 on the 2001 S-Type is:
Bank 2 CMP Sensor disconnected
Bank 2 CMP Sensor gap incorrect / foreign matter on sensor face
Bank 2 CMP Sensor sensing circuit: open circuit, short circuit to ground, short circuit to high voltage
Bank 2 CMP Sensor reference ground circuit (to splice) open circuit
Bank 2 CMP Sensor failure
Although sensor failure is the likely cause, don't discount cleaning required or bad harness connections before splashing the cash.
Old 07-29-2012, 10:45 AM
bigalan's Avatar
thank you both that makes it a lot clere so think the sensors i got are the crankshaft sensors and not the cam shaft sensors i orded have atched a pic of the one thay have sent me this is probly why i cudent see them do these twist rater then un bolt like the one on the pic i posted
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-12-2015 08:15 AM
gregster41
09-06-2015 06:51 PM
gregster41
General Tech Help
09-04-2015 03:51 PM
KarimPA
09-03-2015 07:32 PM
Quick Reply: location of Camshaft Position Sensor
