STR with 75-shot Nitrous
Old 06-02-2013, 04:35 PM
Cambo's Avatar
Received 4,436 Likes on 2,421 Posts
Default STR with 75-shot Nitrous
This is bigtel's car, he came along to Santa Pod yesterday, with a 75-shot of Nitrous
Bottle in the boot
Two solenoids for N2O and fuel
Fuel line to solenoid, taken from the fuel rail
Pair of spray nozzles mounted in the intake pipe, just before the throttle body, one for fuel, one for nitrous
Different angle on the solenoids
Master switch in the center console
Trigger switch under the accellerator pedal
Very simple, turn it on, and put your foot down.
He arrived late so only got a couple of runs in.
1st without NOS, 14.1871 @ 101.96mph
2nd with NOS, on from launch, 12.9976 @ 109.51mph
Car is a high-miler, with 3lb pulley, 200 cell cats, & exhaust.
We were very impressed!
Attached Thumbnails STR with 75-shot Nitrous-bigtel1.jpg   STR with 75-shot Nitrous-bigtel2.jpg   STR with 75-shot Nitrous-bigtel3.jpg   STR with 75-shot Nitrous-bigtel4.jpg   STR with 75-shot Nitrous-bigtel5.jpg
The following 3 users liked this post by Cambo:
Andrew 07 XKR (06-23-2020), Datsports (01-06-2018), Panthro (02-07-2018)
Old 06-02-2013, 06:31 PM
Michael Star's Avatar
Very cool! I have thought a lot about adding nitrous, but I worry about the tranny shifting in between sprays. Is there an rpm switch as well?
Old 06-03-2013, 04:34 PM
Cambo's Avatar
Everything I know about this car is in the first post, so the answer is ????
Old 06-03-2013, 04:58 PM
lol thanks. I keep going back and forth on it.
Old 06-03-2013, 05:43 PM
amgeater's Avatar
110MPH traps. This car should easily run low 12's. With a good 60ft. I really want to learn more info about this setup. This car uses a wot switch, Therefore there's no window switch which is not the way i'd go if it were me with our t/c system. I'd use a dry by wire window switch, which would turn off the spray if the t/c so happened to turn on.There was a guy who posted high 11 sec 1/4 miles times with a 75shot. I was also under the impression that spraying before the supercharger kills the coating on the supercharger rotors. Definitely nice to see the setup. I have a nitrous kit just waiting to get put on.
Old 06-08-2013, 12:36 AM
1320racer's Avatar
I'm having trouble understanding your post amgeater? What do you mean by:
- "our t/c system"? This car is supercharged (s/c), not turbo charged (t/c)
- "I'd use a dry by wire window switch"?Do you mean drive-by-wire?
- "which would turn off the spray if the t/c so happened to turn onThis statement does not make sense.?.?.? If you are racing, the s/c is going to be adding boost. Are you saying you want nitrous only below full throttle?
As a point of reference, I have a good number of runs at slightly greater than 109mph on cool days at the dragstrip/racetrack without using nitrous.
Old 06-08-2013, 02:20 AM
avos's Avatar
Received 1,062 Likes on 759 Posts
The engineneeds to lower its torque for the gearbox to safely change the gears. This is done by torque reduction requests from the TCM to the ECU, which in turn reduces the throttle opening to oblige. So one way (pretty good) to protect yourgearbox from the extra power of the NOS at these points.
Old 06-08-2013, 12:22 PM
androulakis's Avatar
I believe by t/c he is referring to the traction control system. If the car breaks traction and the traction control kicks in and pulls the throttle back (even though you have your foot glued to the floor), he wants the nitrous to turn off to avoid nitrous spraying under part throttle conditions. He's not worried about spraying nitrous if the S/C goes into boost. He wants Nitrous ONLY at full throttle, but only when the car is truly at "full throttle" based on what the ECM is doing, NOT what your foot is doing.
I think he's talking about a drive by wire window switch maybe using the TPS sensor AND an rpm window switch.
Take care,
George
Old 06-09-2013, 07:52 PM
1320racer's Avatar
Oh. T/C = traction control. Now that makes sense. Sorry for being a bit slow in understanding and thanks everyone for the help.
Old 06-23-2020, 11:41 AM
Andrew 07 XKR's Avatar
So cool!!! What year is the STR? Would this same set up work in my 07 XKR???
Old 06-23-2020, 01:12 PM
wydopnthrtl's Avatar
That kit is a WON kit. I highly recommend them! Ramping the nitrous shot has many benefits for a street car.
https://www.noswizard.com/
Old 06-23-2020, 06:49 PM
User 42324's Avatar
This is a 7 year old old thread, but that STR is a late 2002 car. Yes, there's no reason this setup wouldn't work on your car.
Old 06-23-2020, 06:55 PM
User 42324's Avatar
Yes, that's a WON wet NOS kit. It's a 70 shot setup.
Old 06-23-2020, 07:16 PM
Cool
Back 15yrs ago I was a part time engineer for the US sister company. When Trevor was over here he stopped by my home and we discussed a few things.
I still have my WON / Racetested parts too. Not for use on a Jag though..
Old 06-23-2020, 07:47 PM
User 42324's Avatar
Trevor is a good bloke.
I don't know who installed the kit on the car but I'm pretty sure it never worked correctly. I bought the car 5 years ago & it clearly wasn't working properly plus a comment Terry said about when he was running it at the strip. Anyway, I've spent a long time fixing this & tweaking that & now everything works as it should, last year I thought let's try the NOS again. A small gain & not what I expected. Ran it on my usual heartbreaker dyno & although it projected 513 hp the AFR dropped like a stone, which told me the NO wasn't reaching the engine, just extra fuel. Testing the system forwards showed, upon reaching the solenoids, that the NO one wasn't firing, just the fuel one. After so much work with the car, this p1ssed me off somewhat & January this year I removed the NOS - well most of it. It'll be easy to reinstall but it's neutralised - & I was only planning on using it now & again. TBH even on a dry day, I've got the TC flashing up to 50mph on not too much throttle on good tyres. Will I refit it later, probably . . . I've got a full bottle lol.
Old 06-23-2020, 07:59 PM
I helped design / engineer kits for a few kits over here. I know a lot and learned a lot from Trevor and Denny. If you need help sorting it out let me know. (I've not worked on the REVO stuff though)
If your spraying upstream of the IC I'd suggest adding a little acetone to the fuel. I found better cyl to cyl distribution that way in my gen 2 Lightning.
Andrew 07 XKR (06-25-2020)
Old 06-23-2020, 08:12 PM
User 42324's Avatar
Thanks for the offer it's very kind of you. I've got to get around to stripping the solenoid & I doubt it's a blocked jet. I must say I don't really talk about my STR much, so I was a little surprised at the length of the post I wrote.
andystev
10-12-2019 08:50 PM
Mad Hatter
09-10-2019 01:38 PM
Kitchen23
04-23-2018 11:24 AM
kiddhan625
US Mid Atlantic
06-05-2013 07:34 AM
espresso
06-26-2010 02:57 AM
Quick Reply: STR with 75-shot Nitrous
