RPM flare during shifting
I think I spoke too soon, I just got back from a trip up to Liverpool and it is still flaring. It actually seems to be more noticeable in sports mode, where it wasn't so apparant before.
I guess I'll continue to troubleshoot; I'll check fuel trims during shifts next weekend. I've done more than enough miles since the fluid/filter swap that it the gearbox must have readopted, I can't imagine having it reset by my local specialist would make much difference.
Just wondering if you got this flare sorted.
I'm experiencing the same, probably about 50-100 rpm. Had a full atf change some months ago. Some issues with abs after so I think the shift patterns learned badly.
Did you get the adapations reset? Or was it an air leak, maybe from the brake booster pipe quick release? (I had this disconnected twice to replace plugs and gaskets)
I'll get my scanner on the fuel trims and see what it does during shifting.
Feels like something is blipping the throttle as you shift like in an old manual with carbs.
