Upper Timing Chain Tensioners, Plugs, Coils.
I used the basic instruction from EZ Driver that are in the files here.
Tools needed: 1/4 inch drive universal jointed sockets in 7, 8, and 10mm. If you don't have them, don't start this project. You will also need extensions from 3 inches to 24 inches, Universal joints, and a very small torque wrench. I also used my 3/8 drive for the larger sizes 10-14mm. Use rubber gloves...heavy duty type and even those will tear. I used about 30 pairs.
Most difficult part of the job is not damaging the wiring harness. They are already brittle and one screw up can keep you grounded. They use a lot of plastic push through fasteners to hold them in place and Jag didn't waste any wire on this mess.
I also used the Jaguar manual too to see drawings of the small things.
Things I learned:
1. The oil fill tube on the top of the cover is a snap in type. I broke it when I twisted it. Ordered a new one and used a silicone glue/sealer to hold it until the new one arrives.
2. The manual says to unbolt the dipstick tube and pull up to get it over the 1" stud. I did that and it came completely out. Surprise. EZ Driver said his was stuck....OK, so I went back to the Jag Manual and on Page 1300 or so, it showed a drawing. Got it back in the hole. To measure if it is all the way down, just use the dipstick to see if the level is correct.
3. I used air to clean the spark plug cylinders BEFORE I took out the old ones. I used a tiny bit of anti seize on the plugs to be sure I didn't cross thread them and I put them in BEFORE I put the cam covers back on.
Is this an easy job? NO, it does take some mechanical skills. What did I find? My original tensioners didn't look like others that have been shown here. They were not damaged at all and I used my snake camera to look down at the others I wasn't changing. I could only see the races, but they were fine.
My time was about 9 hours for both sides, but I do these type of jobs very slowly.
A few photos are attached. Overall, this model has some very good performance gear, but it is so poorly arranged for any serious wrenching around. Because it is a pain to do even small stuff, I figured I would do a lot at once and f'git about it for a while.
Things I learned:
NBCat (10-20-2016)
When I see the underhood photos of V8 S Types I love my V6 more and more. Access under the hood quite is pleasurable on these models.
I may be biased, this is true, but I damn near skipped mine over due to my love of V8 sedans. I am glad I gave my V6 its chance.
Your photo reminds me of my Olds Silhouette. That's tough company to be in.
Received 6,249 Likes
BTW, the smoothness of the engine didn't change . There was never any indication of a problem.
abonano (10-22-2016)
Received 2,577 Likes
davidladewig (10-23-2016)
I haven't found the front pulley tool yet. Thanks to motorman for the ebay tip but so far I haven't seen what is in the book to do it. I may use a universal and that should do it.
Sump = Oil Pan? If they are in there, they must be in pieces.
I ordered the lowers. Bought the entire kit and it was less than just the lower tensioners.
Crankshaft locking, main tool
303-191
Crankshaft pulley/damper remover
303-588
davidladewig (10-27-2016)
I posted the photos because I had never seen them with a metal foot. I guess there was a reason why. I had an import tech come and check the chains. He said they are fine and looked new to him, so those are staying and only tensioners and races are going on. Piece of cake. The mileage is about 73,000. It takes tons more time to disassemble the covers and junk than to make the repair.
But...while I have it apart, a new metal t-stat housing is going on an few new hoses I have packed away.
I found that wratchets and u-joint tools were a problem. Got sever new ones with much more flexibility and that should make some things easier.
Did you also purchase the crankshaft holding, or setting tool that fits it place of the crankshaft position sensor?
Crankshaft Setting Peg 303-645
I don't have a peg yet. One indy shop said I didn't need it and one did. One told me to put the socket on the nut with a bar and bump the starter. When I asked if he was kidding, he said no, that is how they get them off jags to put in new oil seals. I am going under the car today and see if i can reach the peg spot and then decide what to do.
