power seats not working
Old 05-11-2009, 05:51 PM
wazari's Avatar
The connector(s) under the seat came loose.
Old 05-13-2009, 06:09 PM
if the connectors are connected try unplugging the seat module and plugging it back in sometimes they get locked up.....only way to fix that problem though is to replace the module
Old 05-19-2009, 09:37 PM
jimmypopjunkie's Avatar
I have the same problem.. the drivers side power seat does not work. Any thoughts on testing what the problem could be? The used dealer where I purchased the car thinks it may need a new module. where is this module located? and anywhere besides the dealer to purchase a new one?
Old 05-20-2009, 06:04 PM
you can by used ones.. under the seat..
Old 05-20-2009, 06:45 PM
I have good used seat modules in stock, and yes, you can remove the one from beneath the passenger's seat and test the circuit by plugging it in on the driver's side.
I don't think I ever met a Jaguar mechanic who was trying to steal bread off the table of a Kraut can mechanic.
Old 07-22-2009, 01:42 PM
I have the same issue and need a replacement module. If someone can give me a link or a PM on the cheapest/best place to get one from. Mine is for an 03 XJ8. Additionally, unless it sticks when there is no power/module bad the switch on the side of the seat (driver's seat) is stuck in the position to slide the seat backwards. I may need new controls also if someone knows where to get them.
Thanks,
Mark
Old 03-06-2010, 05:32 PM
Gus's Avatar
Gus
Gus is offline
retromotors (01-30-2015)
Old 08-24-2010, 08:12 AM
DickKing's Avatar
I am having the same issues with the passenger seat. The switch clicks when pressed, but nothing happens. The fuses are ok. Does anyone know where to get new switches and how to replace them?
Old 08-24-2010, 04:21 PM
QuadManiac's Avatar
Dick, what year/model? Assuming it's similar to mine, if when pressing the switch you hear a click from somewhere away from the switch, it is not the switch. It will be the motor, the Seat Control Module, or the wiring in between them. I believe you can swap Seat Contol Modules from left to right to determine which.
Old 08-27-2010, 12:02 PM
DickKing's Avatar
Thanks, I swaped the modules and was able to adjust the seat so it is now comfortable.
Old 08-27-2010, 08:14 PM
QuadManiac's Avatar
And as driver, I believe it is your prerogative to KEEP the working module on your side!
Old 12-28-2014, 07:59 PM
timmi's Avatar
Question Need help on relay
I have a 2001 jaguar VDP and was told to check if relay wasn't working first but I don't know what to locate it for the driver seat ... (not working) Appreciate help or diagram ... thx
Old 12-28-2014, 08:05 PM
timmi's Avatar
is the fuse on the left rear or the right rear? my driver sear is out ... thanks
Old 12-29-2014, 05:57 AM
retromotors's Avatar
Originally Posted by timmi
is the fuse on the left rear or the right rear?.....
I won't try to answer because our cars may be different.
On my '98 YM, the cover for the fuse box in the trunk has the fuse layout diagrams for all 5 of the car's fuse boxes!
Go figure!
Guess it's one of those ... "seemed like a good idea at the time."
Old 01-30-2015, 02:47 PM
Fred_WD8KNI's Avatar
Default Driver Power Seat Switch
Ok, so how do I get the switch out of the seat? Everything works except forward.
1999 XJ8, Thanks in advance.. Fred
Quick Reply: power seats not working
