Colder sparkplug for s/c AJ-V8 ?
EDITED FOR ACCURACY 3rd MARCH 2017
The OEM sparkplug for the AJ-V8's
3.5L
4.0L (AJ27) n/a and s/c
4.2L n/a and s/c
I̶s̶ ̶t̶h̶e̶ ̶D̶e̶n̶s̶o̶ ̶3̶3̶5̶6̶ ̶I̶r̶i̶d̶i̶u̶m̶ ̶(̶S̶K̶1̶6̶P̶R̶-̶A̶1̶1̶)̶, which is a heat range "Denso 16" equivalent to NGK 5, which is the hottest range available.
EDIT
The OEM plug p/n C2A1535, which replaces AJ84575 is actually NGK IFR5N-10 for all markets except the Middle East, which use different versions depending on the vehicle model. For the 4.2L X150 XKR there are two versions for Middle East market cars.
C2A1535 = NGK IFR5N-10
AJ812842 = NGK IFR6N-10
C2C41805 = NGK IFR7N-10
IFR7N-10 is also the Aston Martin part number 6G43-07-10056
Gap range is specified 0.35-0.40 inches. (0.9 - 1.0mm)
The general consensus on the internet is that forced induction engines need a plug which is one or two heat ranges lower than naturally aspirated engines. So it's a little surprising to me that the OEM plugs are the same for both the naturally aspirated and supercharged versions of these engines.
There is an NGK equivalent to the OEM Denso plug, the NGK IFR5E11, heat range 5, same as Denso heat range 16. EDIT, these are the wrong gap
There is also a compatible plug from NGK that is one heat range cooler, the NGK IFR6E11 (from a 1.5L Mazda 3 of all things). EDIT, these are the wrong gap
I'm just wondering, for those of us with supercharged engines, who have smaller pulley's, engine tunes, etc, have we ignored/overlooked the spark plugs?
3.5L
4.2L n/a and s/c
EDIT
Top Answer
02-23-2017, 05:35 AM
I worked at Jag as a engine management cal engineer when these engines were being developed (still do infact).
The reason for the "5" heat range plug was to meet sign off for plug foul in extreme cold temperatures. The decision to keep NA and SC engine the same was to prevent NA plugs going into a SC engine by mistake at the factory.
Hot plugs do not cause detonation, they cause pre ignition. Which is very hard to detect, and very destructive. The standard tune on 4.2 SC's (and the NA's for that matter) is tuned to not get the spark plugs to hot. There is an area of the ignition map that is deliberately retarded for this, it is set by using instrumented spark plugs. And in this area the plugs will get hot enough to cause engine failure levels of pre ignition way before any spark induced detonation occurs.
Obviously, anybody trying to tune one of these engines in the after market will not be able to measure this. So fitting colder plugs is absolutely the right way to go. And as others have said, the Aston 4.3 plug is a direct fit.
Sean
Sean
With a bit more searching I came across some info for the Aston V8 Vantage, they use an NGK 7 range plug. Spark Plug and Coil Options for 07 V8V - 6SpeedOnline - Porsche Forum and Luxury Car Resource
I know the coils on the AM are different to the Jag ones, but maybe the plugs could be interchangeable?
Received 1,231 Likes
makes sense to use a colder plug for forced induction vs N/A, and correct most engine guys do that !
but i,m thinking only the super high boost engine make use of it!
way back 45yrs i used a flat gap plugs in a boosted chevy , like 35/40psig manifold pressure!
i tried some regular gap cold range plugs , one single blast drag track, burnt the electrodes right off the cold side , that was using cold Methanol fuel also!
but todays Iridium are lightyears ahead in sparkplug technology!
came across this pic at BONNEVILLE top speed track, i was a spectator,2007.
Sun coming UP over the horizon around 6.00/ 6:30 AM , 20 miles wide 80 miles long, clouds just breaking, deathly silent , no engines till 8:00 am!
sit out down track,folding chair , cup coffee, NICE start of a great day!
way off in back ground you can just see some cars pushing out to start area!
Stroked 4.2 conversion, but all the electronics came from AJ26.
Cambo (02-19-2017)
You can see that their system gives 6 for stock AJ26S but for AJ27S or later just 5....hmmmm...
but NCA385OHA 2 for AJ26S and NCA385OFA 1 up to 1999 MY AJ26 N/A.
Maybe the material change explains the difference?
Panthro (03-02-2017)
Datsports (02-20-2017)
3.5L
4.2L n/a and s/c
Is the Denso 3356 Iridium (SK16PR-A11), which is a heat range "Denso 16" equivalent to NGK 5, which is the hottest range available.
3.5L
4.2L n/a and s/c
and it may have been necessary to use the heat range 5 plug for self cleaning reasons to achieve plug service intervals close to the 100000 km mark.
It's the opposite way mate. 5 is the hottest, 7 is cooler.
It's normal to use a cooler plug on a forced induction engine.
Which is why i'm miffed that the naturally aspirated Aston AJV8 runs a 7, and the supercharged Jag V8 runs a 5.
You're not going to melt a piston or break something by running a cooler plug, the opposite actually, hotter plugs are more prone to detonation...
Maybe the sc is just right and the na is just gets what they had already bulk purchased .
as for the AM there must be a reason . my guess is the 5 will self clean for long life duration .
and the am probably wants to charge you for the more regular plug change ,
