Fuse Chart 2002 XK8/R FAQ
After answering a question on fuse location I realized that we have not posted a fuse chart on our FAQ Sticky.
Here is the one for my 2002 XK8. Other years may be slightly different but generally these should apply to all years through 2002 and perhaps beyond. I suspect that they may also largely apply to the XJ8/R series.
The following 9 users liked this post by test point:
cagneykitty (09-29-2015),
JayJagJay (06-01-2017),
Jen & Neil (05-03-2011),
obwoodie (11-27-2015),
Orthodixie (05-27-2017),
and 4 others liked this post.
Received 9,005 Likes
The following 4 users liked this post by JimC64:
That is correct Mad, unfortunately. New users need a specified time of membership, plus a minimum post count before privileges are granted.
If you drop your email here, Testpoint could email it to you. Or, you could wait. The qualifying period is not long, but you will need to drop a few more posts...i'd say between 3-5. If you haven't been to the New Member area, please drop by and introduce yourself, or respond to some other threads. You'll be there in no-time.
ALSO Does anyone know where can I find the fuse for the Boot / Trunk lights (Internal)
Received 6,243 Likes
Have you checked whether the connector directly behind the cig. lighter outlet under the console is plugged in?
I thought I would add the relay locations (2001) to this faq, so we have the fuses and relays in one place:-
XK Relay Locations 2001.pdf
The following 3 users liked this post by dibbit:
