Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Swap of ZF6HP26 to ZF6HP28
Old 07-29-2014, 05:39 AM
Sochi2014's Avatar
Default Swap of ZF6HP26 to ZF6HP28
Wondering if subject is possible for X350 XJ? Both boxes are from jags.
Old 08-19-2014, 01:53 AM
MoscowLeaper's Avatar
Nope. The TCM and mechatronic units are different, they are not interchangable, and you can't program 6hp28 to work on a x350 CAN bus.
If you want a stronger tranny it's better to go an EXEDY route.
Sochi2014 (08-19-2014)
Old 08-19-2014, 04:59 AM
Sochi2014's Avatar
MoscowLeaper
Thanks! I don't need stronger yet, just would like faster shifting and overall operating. Even trying to feed mechatronic by x350's TCM i have zero chances? As i understand the mechanical part of 6hp28 transmission can be swapped (to make it stronger)? But the mechatronic is the point of my target..
Old 08-19-2014, 08:31 AM
It can be swapped, but it will fail sooner or later w/o a correct mechatronic unit.
Change fluid/pan+filter, reflash TCM with latest s/w, erase adaptations and perform an adaptation procedure with SDD (tricky enough).
To be honest i don't have any issues with operating speed and quality.
If you'd like to we can continue in e-mail, on russian language
nick at oldjaguar dot com
boostedxf (06-07-2022)
studentper
02-20-2016 09:43 PM
Newark Nj Gang
10-02-2015 02:39 PM
millertic
09-30-2015 08:11 PM
pnwrs2000
09-30-2015 01:56 PM
Mark SF
09-28-2015 01:51 PM
Quick Reply: Swap of ZF6HP26 to ZF6HP28
