2003 X-Type... Locked Keys in Trunk
Old 11-29-2010, 08:35 AM
TheSeeker's Avatar
Your trunk button must have worked prior to this if you managed to lock the keys in there.
Whenever all the doors are unlocked, your trunk button should unlock the trunk.
Old 11-29-2010, 12:28 PM
exrub's Avatar
This may sound crazy, but...
If you have a sturdy yard stick (not too thick), you could slide it between the seats where the 70/30 seatback separation is and try to "push" the seatback release knob. For instance, I have an aluminum one that probably would slide rather easily between the seatbacks. Then, you'd just have to try to fiddle with it to aim for the release knob.
Whatever you try, good luck!
Old 11-30-2010, 12:27 AM
Rockyf's Avatar
How about removing the seats completely? According to the repair manual you have to remove the lower cushion then the back (upper). The only thing is that you will have to buy the pins that hold the seats when you reinstall them because they are breakables. Only the dealers have them or order them online. If you don't have the JTIS, it is downloadable in the FAQ section.
Good luck!
dsnyder586
04-04-2019 02:38 PM
XJsc-guy
11-23-2015 01:56 PM
findre
09-10-2015 05:46 PM
kabs3012
US Midwest
09-10-2015 01:17 PM
speacock
09-10-2015 12:14 AM
Quick Reply: 2003 X-Type... Locked Keys in Trunk
