2002 X-type reliability
Old 05-03-2008, 12:16 PM
310jag's Avatar
Default RE: 2002 X-type reliability
Trannies (auto), driveshafts, some occasional wheel bearing issues, etc. The big thing I would look for is rust. Check the rocker panels, and behind the front fenders where the front door meets the rear of the front fender. Lots of Xs have serious damage in this area.
That's all I can think of off hand. I've got an 02, and it's been more reliable than just about any other car we've had, including an 03 Sentra econobox.
Old 05-03-2008, 06:56 PM
I have an 02 and so far so good. I read prior to purchasing mine that the auto trannys were junk, so I purposely went for a 5-speed. Mine really has been a good car.
Old 05-04-2008, 07:51 PM
MarkC's Avatar
ORIGINAL: mackey
92,000 miles. I'm not sure which engine. I'll find out tomorrow. I'm concerned about drivetrain issues because I need a decent car that will last me a while that will not cost me much money in maintenance.
Let's be honest. If low maintenance cost is a priority, you really shouldn't be looking at a Jaguar.
Old 05-04-2008, 09:11 PM
jvegas's Avatar
good point.
Old 05-04-2008, 09:57 PM
Dennis's Avatar
ud
That 02 with 92K, has probably seen it's better day....And true, they cost a lot to fix..So my advise would be, get a late year 03 or an 04, plus an extended warranty if you can afford it, it's well worth the initial cost....
Old 05-05-2008, 06:25 PM
MarkC's Avatar
I consider having a manual transmission a "plus". Reasonably fun to drive, slightly better gas mileage, and far less issues than the automatics of that year.
For $5K, I'd be tempted too... but I do most of the repairs and maintenance myself. If you expect to pay someone for any and all maintenance and repairs, I would suggest you look elsewhere.
Old 05-05-2008, 11:18 PM
jvegas's Avatar
offer her $3k... can't hurt.
Old 05-08-2008, 11:00 AM
mkaresh's Avatar
I'd definitely have a mechanic who knows Jaguars look it over. There could be problems she's unaware of.
Wish I could provide more info, but the X-Type isn't yet included in my site's reliability survey. Maybe in a few months.
Old 08-01-2010, 09:53 PM
scubaguy10's Avatar
Having driven an 02 X type manual to 170,000 miles, I can tell you what I saw for problems. The drive shaft went bad and had to be replaced. That was the biggest single issue. I replaced the starter motor at about 120,000, and last year had an issue with the speed sensor for the ABS that required the replacement of the wheel hub. Welsh Jaguar had the hub as a part, otherwise the dealer wanted $800 for the entire hub/ CV joint assembly. Other than that, all maintenance was pretty normal. At 170,000 miles, it still had the original clutch, alternator, and brake rotors.
Old 08-02-2010, 07:26 AM
rand49er's Avatar
Originally Posted by scubaguy10
... At 170,000 miles, it still had the original clutch, alternator, and brake rotors.
I'd like to be able to say that. ^^^
Old 08-02-2010, 05:33 PM
vai1953's Avatar
I have an 02 2.5, had it a little over a year. When I got it there was 87,000, it just turned 95,000. Still runs great and with the automatic tranny, I would have liked to have gotten it with the standard. But I've found no problems with the automatic tranny, I've had it out and not all the way open at 130 mph runs and rides great. Sometimes, a little more miles makes the car a better car cause all the bugs have been cleaned up, now it's just worn parts you have to think about, so far I love my high milage Jaguar.
reyesfam (10-27-2014)
Old 08-02-2010, 11:21 PM
PreJag's Avatar
Bought mine w/49K on the clock. I've run 15K since with only the replacement of the front axles and one front door speaker. Both the axles had dried-out CVs resulting from lack of use by the previous owner. The speaker suffered from the famous 'dropped magnet' syndrome. Sure, it's got some of the well known early model problems and I need to take care of them, but they are really insignificant to the car running well on a daily basis.
Old 08-04-2010, 12:09 AM
gsd2004's Avatar
You guys do know this thread is over 2 years old. To make my post worthwhile our 02 has 55,000 miles and the largest item we have fixed has been the prop shaft.
Old 10-19-2014, 01:32 PM
charmaine89's Avatar
Default break pulsation with knocking noise
I have a jaguar x-type 2.5
When I hit the break the break pedal vibrates and makes a knocking noise somewhere under the car.
I got all my break pads and front rotors replaced and it is still doing the same thing.
the Abs light on the dashboard isn't on. Did anybody have this problem?
need help please
Amberlinder541
09-30-2015 07:07 PM
BlakeConverse
09-28-2015 02:22 PM
jessejamestw23
09-26-2015 03:57 PM
Amberlinder541
09-26-2015 01:10 PM
zdrapec
09-25-2015 05:49 AM
Quick Reply: 2002 X-type reliability
