2003
Hello & welcome . Could be !! ABS unit ( Under bonnet /Hood ) Reluctor /Speed rings on any of the 4 wheels , ABS sensors ,brake ib ABS sensor cable etc , etc . As Paul said , get the codes read & diagnose the fault . I doubt its the ABDS unit & anything else should be a reasonably easy fix. Also Jag X type parts are not to expensive .
Received 3,825 Likes
bachour, get the codes read. With the information that you provided, it could be way too many things. Hope that it is one of the following codes: C1145, C1155, C1165, or C1175. This would be one of the speed sensors and that is normally a pretty easy and cheap fix. I am placing money that it is more than likely either C1165 or C1175.
Thank u
bachour, based on you getting all 4 codes, that would lead me to believe that you have a problem with your ABS unit or the plug for the unit is not seated properly and it is not making proper connections. Let me get home and look at the diagrams and lets see what we can find from there. It may be something as simple as the fuse to the ABS computer/module is blown. Hard to say what you may find.
SoCalJagS
09-27-2015 09:20 AM
