Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
LinkBack Thread Tools Search this Thread
Old 01-03-2010, 12:19 PM
Default 2004 Xtype fuse box diagram
Does anyone have a 2004 xtype fuse box diagram .. i have a sedan 3.0 if that matters
Old 01-03-2010, 07:32 PM
Thermo's Avatar
Engine compartment fuses
Fuse Type Rating (amps) Colour Circuit
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay,
air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Engine compartment relays
Relay No Type Rating (amps) Colour Circuit
R1 ISO 40 A 40A Black Windscreen wipers.
R2 ISO 70 A 70A Grey Heated front windscreen (optional).
R3 Micro 20 A 20A Black Horn.
R4 Micro 20 A 20A Black Accessories (optional).
R5 Micro 20 A 20A Black Headlight powerwash (optional).
R6 Micro 20 A 20A Black Air conditioning compressor clutch.
R7 ISO 70 A 70A Grey Engine management system.
R8 Micro 20 A 20A Black Automatic transmission control module.
R9 ISO 40 A 40A Black Dip beam/HID.
R10 ISO 40 A 40A Black Starter motor.
R11 Micro 20 A 20A Black Throttle motor.
Passenger compartment fuses
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand – front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand – front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control
module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module,
VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power
supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module,
Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid,
electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid,
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission
rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.
Now, all of these are for a 2003 model car, but they should be close enough to give you the info that you are after. If you have any questions, let me know. If you want the computer files for the 2003 manuals, let me know. I have all of them.
__________________
Chris "Thermo" Coleman and K'Re Ann, the 03 X
Old 01-04-2010, 06:59 AM
thanks .. yeah this is good stuff.. my heated seats dont work and my hazzard lights..that would top switch stopped working thought it might be a fuse or something .. i dont know what else it would be .. any ideas?
Old 01-04-2010, 03:27 PM
Thermo's Avatar
unboxed, I am assuming that your turn signals work just fine. What you need to do is pull the radio out of the dash and re-plug in the connector on the back of your hazzard/heated seat assembly. From the sounds of things, that has come disconnected and is therefore causing your issues. The two systems are completely separate other than running through a common plug. Let me know if this is or is not the case. I will be curious as to what the answer is.
__________________
Old 01-04-2010, 06:21 PM
Photobucket
Send a message via MSN to JimC64 Send a message via Skype™ to JimC64
Click the image to open in full size.
Nice one Thermo
You could also try checking out the post in the x type faq quick link thread unboxed although it is also for an 03 I believe but has a diagram as well
__________________
Jim
A day without sunshine, is like, well, NIGHT!
Nothing is foolproof to a sufficiently talented fool!!
A fine is a tax for doing wrong, A tax is a fine for doing well......
The things that come to those that wait, may well be the things left there by those who got there first!!
MY2007 Audi A6 3.0 Tdi SE Quattro 176bhp Stratos Blue, Front & Rear park assist, Comms Pack High, Sline grille badge, 19" 7 twin spoke RS4 alloys, Rear tints, Dipped bulbs 80W, Mainbeams 100W, Foglights 100W, Number plate bulb LED's, Interior bulb LED's, First Aid Kit, Bootliner, Mudflaps front & rear, Calipers & hubs painted.
MY2004 VW Passat 1.9 Tdi Highline
LANG MAY YER LUM REEK
**********************Contact-Admin // Forum-Rules // New-member-Must-Read // Vendor-directory**********************
If you've been helped, please click on the "Thanks" button
Old 01-04-2010, 06:46 PM
Thermo .. that would make sense .. cause i did have an after market radio put in and it stopped working around that time .. ill check it out thanks again
Old 08-17-2010, 11:25 AM
Default Fuse/Relay
Thermo, I am learning to love your posts however on this one your fuse and relay locations do not match mine that I have physically tested nor my owners maunel whatsoever. I have a 2004 x-type 3.0
Old 11-04-2011, 12:04 AM
FUSE DIAGRAM FOR 2004 X-TYPE AWD 3.0
Engine Compartment Fuses (1)
Fuse No Rating (amps
) Circuit
F1 10 Right-hand main beam.
F2 15 Front fog lights, master light switch.
F3 Not used.
F4 10 Left-hand main beam.
F5 10 Air conditioning compressor clutch.
F6 7.5 Generator.
F7 Not used.
F8 30 Wiper switch.
F9 30 Wiper switch, windscreen washer pump, wiper motor.
F10 15 Ignition coils.
F11 15 Automatic transmission control module.
F12 Not used.
F13 5 Traction control system, anti-lock braking system, dynamic stability control system.
F14 30 Heated front screen left-hand side.
F15 30 Heated front screen right-hand side.
F16 5 Radiator fans speed control.
F17 10 Fuel injectors.
F18 10 Canister purge valve, airflow meter, inlet manifold tuning valve, canister close valve, vacuum module.
F19 10 Engine control module. Throttle motor relay.
F20 30 Oxygen sensor heaters B.
F21 30 Oxygen sensor heaters A.
F22 Not used.
F23 Not used.
F24 30 Power wash pump.
F25 Not used.
F26 Not used.
F27 15 Transit relay, vacuum module, battery-backed sounder.
F28 Not used.
F29 20 Left-hand dip beam, master light switch (autolights), head light levelling, instrument panel.
F30 20 Right-hand dipped beam.
F31 Not used.
F32 15 Automatic transmission control module.
F33 Not used.
F34 30 Starter motor solenoid.
F35 5 Ignition relay coil.
F36 5 Engine control module.
F37 Not used.
F38 20 Horns. Auxiliary heater
Passenger Compartment Fuses (2)
) Circuit
F1 Not used.
F2 10 Instrument panel, electrochromic mirror, reverse light switch, reverse lights.
F3 30 Passenger seat adjustment motors.
F4 20 Accessory connectors.
F5 20 Rear wiper (Wagon only).
F6 Not used.
F7 10 On board diagnostics, heated front seat modules, rain sensing system, JaguarVoice.
F8 20 Heated front seat modules.
F9 10 Driver’s seat memory function.
F10 15 Sunroof module, SRX antenna.
F11 20 Left-hand (front and rear) electric window motors.
F12 10 JaguarVoice.
F13 Not used.
F14 30 Heated rear screen.
F15 10 Heated door mirrors.
F16 30 Driver’s seat adjustment motors.
F17 20 Fuel pump driver module and relay.
F18 15 Rear accessory socket (Wagon only).
F19 30 Tow-bar module. Rear accessory socket (Wagon only).
F20 30 Premium ICE amplifier unit.
F21 20 Right-hand (front and rear) electric window motors.
F22 15 Door lock module.
F23 20 Rear screenwash pump (Wagon only).
F24 20 Screenwash pump.
F25 5 On board diagnostics.
F26 10 Manual transmission cruise control clutch switch, rotary switch.
F27 5 Touch-screen.
F28 15 Front and rear accessory sockets.
F29 7.5 Rear fog lights.
F30 5 In-car telephone, PSE.
F31 15 Ignition switch.
F32 5 On board diagnostics.
Old 01-07-2013, 07:23 PM
Thermo, I just brought a used 2005 x-type vdp. The radio doesnt turn on at all, do you have the fuse diagram for the panel under the steering wheel?
Old 01-08-2013, 10:09 AM
Thermo's Avatar
New2me, PM me your e-mail address and I will send you the wiring diagrams for your car. Worst case, put your e-mail address here and I will grab it from here.
__________________
The Following User Says Thank You to Thermo For This Useful Post:
new2me (01-09-2013)
Old 01-08-2013, 01:17 PM
reyesl's Avatar
Quote:
You may also download manuals from here:
TOPIx - TOPIx
TOPIx - TOPIx
Jaguar electrical reference
__________________
2004 VDP
2004 X-Type
2000 Durango SLT
2007 Jeep Liberty
The Following User Says Thank You to reyesl For This Useful Post:
new2me (01-09-2013)
Old 01-09-2013, 06:39 PM
Thermo and reysl, thanks for the quick replies. It looks like I don't have the ability to send a PM, is there something i need to unlock this feature? I will try the links reyesl posted but I am sure there are more questions I am going to have and hopefully be able to help answer at some point. I must admit this forum is a great resource.
Old 01-09-2013, 09:38 PM
RickMG's Avatar
Try this for a location diagram.
Jaguar X Type passenger bay fuse box
Jaguar X Type Engine Bay Fuse box
They copy and print well on Word.
The Following User Says Thank You to RickMG For This Useful Post:
new2me (01-12-2013)
Old 01-10-2013, 07:03 AM
Thermo's Avatar
new2me, you need to have 10 posts before some of the features of the site will be unlocked.
__________________
Old 01-10-2013, 12:18 PM
astromorg's Avatar
The Fuse panel details from Thermo are, as he says, for MY2003 and earlier. For MY2004.25 there was a major update to the wiring harness arrangements and a re-numbering of the fuses plus the wiring was changed from hard wiring into the fuse panels to plug-in.
This link covers most years up to 2007: jaguar.bttlxe.com - /xtype/Electrical/
__________________
2005 XK8 4.2S Coupe
2005 X Type 2.5 SE Auto
Old 01-10-2013, 03:22 PM
All,
Thanks for the responses but I have looked through the links and I cant seem to find what I need. The Topix site wont let me login after I created an account, the link astormorg has a fuse panel that looks like mine but it only describes the relays and not the fuses. My x-type is a left hand drive and the fuse panel under the steering wheel is F1 - F55. Thermo I sent you a PM or atleast i think I did, if not please let me know.
Old 01-10-2013, 04:28 PM
astromorg's Avatar
In the link I gave you, you have to get into the wiring diagrams section to identify the fuse details. However, that's messy if you want an overall list, so go back to Topix - you don't even have to register to get the handbook details. Go to the X Type, year 2004, select the Owner tab then Handbook, then Roadside Emergency. The list of fuses begins on page 174
__________________
2005 XK8 4.2S Coupe
The Following User Says Thank You to astromorg For This Useful Post:
new2me (01-12-2013)
Old 01-12-2013, 08:40 AM
Thanks everyone for you help it was the fuse. I have to admit those wiring diagrams were much more than what I was asking for but I would rather have to much information instead of to little. The factory radio has a good sound to it.
Old 01-16-2013, 04:56 PM
Hi folks, I'm having issues with MY central locking too. Is the diagram given above the same for a 2005 x type estate? If not could someone post up that diagram please?
__________________
X-type 2.0 diesel estate 2005.
LDV Pilot van 1.9d
Old 01-17-2013, 09:01 AM
Thermo's Avatar
smnp, the above link should do you just fine. Please keep in mind that the diagrams for the door locks is specific to the region of the world that you are in. The locking system in the US is not the same that is used in say England (single lock verses double lock). So, please keep that in mind.
__________________
smnp (01-17-2013)
Tags
2003, 2004, blower, box, diagram, engine, fuse, heater, jaguar, light, management, oxygen, put, relay, sensor, type, xj, xtype
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
