Adding a second key?
Hello,
Some conflicting information on the net about this and hope you guys can confirm.
I bought my car with just 1 key and I thought I might be able to buy a used key off eBay, replace the blade and then reprogramme the fob myself using the 4xignition method... Is it possible or will the transponder in the eBay bought key need some external (main dealer) reprogramming?
Received 3,825 Likes
fico, yes and no. I am sure I just confused you. Let me explain.
Yes: The keyfob will unlock the doors and you will be able to use the features of the keyfob by following the programming instructions.
No: If you are looking to have the key to start the car, it WILL NOT WORK!!!!!! This requires 2 already programmed keys to accomplish or you need the special dealership computer to override the computer.
Keep in mind that there are 2 different numbers that the fob has. One is for starting the car, the other is for all the other functions. Hence the difference.
Wolfy
04-06-2019 10:40 PM
Jzar
09-27-2015 02:55 PM
