Blank Navigation screen
Old 04-28-2008, 08:03 AM
solidx's Avatar
Default RE: Blank Navigation screen
ORIGINAL: bojangles
also can anyone tell me if the 3D option is back in the latest sw version?
I liked it with my original 02 nav software. but when the dealer re-flashed it .. it added a clock.. (good) but lost the 3D.
Check the version of the S/W you have - I got the 3D feature and the clock - I will post all info later.
Old 04-29-2008, 12:50 PM
solidx's Avatar
I will email you with instructions.
Old 04-29-2008, 03:14 PM
solidx's Avatar
1. BURN INTO A DUAL LAYER DVD-R - LOOSE - JUST DRAG AND DROP INSIDE DVD-R
2. TURN ON IGNITION AND TAKE OUT MAP DVD.
3. INSERT THE SOFTWARE DVD-R INTO READER AND QUICKLY TURN IGNITION OFF THEN BACK ON, SO SOFTWARE LOADS WHEN SYSTEM LOADS.
4. WAIT A FEW MINUTES - 5-10 UNTIL YOU SEE THE JAGUAR SPLASH SCREEN COME UP.
If this doesnt work for you then you might need help with the DVD-reader Or you might have burned the file incorrectly.
Old 05-18-2008, 04:10 PM
jvegas's Avatar
so does anyone know what version has the 3d feature??
Old 05-18-2008, 04:49 PM
canman's Avatar
Could I get a copy of the latest 2008 Map? My car is a 2002 and the current Mapis 2003, it is very outdated in new subdivisions, but it works and in 3D. It would be nice to have the updated streets.
  #28
Old 05-18-2008, 05:06 PM
jvegas's Avatar
where do you get updated maps from?
Old 05-18-2008, 10:04 PM
solidx's Avatar
Ok_ Thi seems to be the same issue that I had with mine. Burn the DVD loose again and at the slower speed. Turn the ignition on so you can insert the DVD. Turn the ignition off then back on so the operating system boots up again and can actually see the DVD in the reader when it first loads. Leave the ignition for 10 minutes and let it load. If you done it correctly it should come back up. If I'm you I would let it there for at least 15 minutes and see what happens. If it's an OS issue it should load, if it's the reader then you will have to check it at the dealer and/or have it replaced. let us know.
I downloaded the torrent file. I will not post that here so email me - I will search for the link and explain.
  #31
Old 05-19-2008, 01:03 PM
solidx's Avatar
No there is not change since this is for the device to load properly. To fix the boot sequence. Check to see how are you burning the file - I used a Verbatim Dual Layer DVD-R and the slowest speed - You can use PowerIso or MagicIso to burn the file loose.
  #33
Old 07-28-2009, 07:04 PM
tomjc422's Avatar
Hi, I have the same problem...blank nav screen and flashing codes 50 and 51. Does anyone have a the software update I could use to try to update my system? Thanks
  #39
Old 11-11-2009, 12:22 AM
Gonzales23's Avatar
plees help me with this HARD FINDING s/w update DVD,the jaguar service here in slovenia is very very embarrassing and shameful,becouse they told me that such thing doesn't even existe lol...now what about that!!! Soo plees sand me that S/W update DVD,to flash back/rool back driver's...THX and greatings from SLO =)
  #40
Old 11-19-2009, 07:24 AM
mullisrd's Avatar
I am having the same issue with my XJ. I need the file to burn to DVD to boot. Please send it to me if you have it, I would appreciate it. Thanks.
Quick Reply: Blank Navigation screen
